09-25-2013, 06:27 PM | #1 |
Rock Stacker Join Date: Mar 2013 Location: Temecula
| Driveshaft and gear install
I Purchased the MIP driveshafts for my scx10 along with steel idler gear and steel outdrive gear. my question is how hard a install are these? time consuming? never installed things like these. Thanks |
09-25-2013, 06:34 PM | #2 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Driveshaft and gear install
great upgrade! very simple, the gears are a direct swap once you have the case open. nothing really to think about other than how it all bolts back together, which is also fairly simple. if you have trouble, you can look at the axial manual for assembly instructions. once you do it, you'll be able to do this again in a heartbeat. on the MIP shafts, follow the directions and make sure you get all the pins in the correct direction to avoid any binding points, as i've heard of some people having difficulty with those for some reason (i was fine and didn't read anything and it was my first time). other than that, the whole swap should take you around 1hr-1.5hrs for the first time i'd guess. most of that time you'll probably just be looking at it figuring out how it all connects. something to consider while doing this tranny stuff is to mirror the transmission for combating torque twist. for this you have to swap around the spur gear shaft to the other side, it's a little more involved, but still fairly simple once you know how it all goes together. |
09-25-2013, 06:42 PM | #3 | |
| Re: Driveshaft and gear install Quote:
cool thanks for the advice. I was told to get the traxxas 4x15mm screw pins also to make the driveshafts work with the rubicon kit. so i ordered those also. | |
Driveshaft and gear install - Similar Threads | ||||
AX30401 Install Help! Gear shaft sticks out further than stock | jhonchua | Axial SCX-10 | 4 | 07-24-2012 08:15 AM |
Motor Install Gear Mesh??? | skullking | Venom Creeper | 9 | 02-09-2010 01:48 PM |
how to install driveshaft retainer rings an ax10 | 2004neonsrt4 | Newbie General | 5 | 05-17-2008 09:27 AM |
Motor mounting/gear mesh in R2D- Install Tips? | gr33nlite | Newbie General | 2 | 11-14-2007 11:53 PM |
Spur gear adaptor for Pede install ?? | Gabe | Newbie General | 13 | 03-26-2006 01:42 AM |
