09-28-2013, 08:05 AM | #1 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
| suspension links question
Are all the after market suspension links shorter then stock? My Rubicon has 120mm front lowers and 130mm rear lowers and everything I find for scx10's are shorter.
09-28-2013, 08:56 AM | #2 |
Newbie Join Date: Sep 2013 Location: WDM
| Re: suspension links question
I bought blue monkey titanium for the rear and they were the right size.
09-28-2013, 09:24 AM | #3 |
Quarry Creeper Join Date: Jun 2013 Location: Tacoma
Rubicon is a different length from other kits. I believe the Honcho and Rubicon are the same length while the Dingo is a shorter kit. You have to check link sizes prior to purchase so you dont buy the wrong ones.
09-28-2013, 09:40 AM | #4 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
You should take into account which measurement you are using. Is it eye to eye, or is it the aluminum rod (if you already have the upgraded links,like what come with the kit). Also, all rod ends aren't the same, so you need to pick the right length for what you need. Also,the honcho and Wrangler have the same wheelbase. The dingo is just under an inch shorter. |
09-28-2013, 06:33 PM | #5 |
Newbie Join Date: Jan 2013 Location: West Columbia, SC
Or you can make your own really easy. get 1/4in brake line for a auto parts store threaded bar i believe its 8/32in or what ever fits in side the brake line from a hard wear store like lowes and traxxas rods ends and a dremel . i found a video on youtube. they were fun making them
09-28-2013, 08:03 PM | #6 | |
| Re: suspension links question Quote:
09-28-2013, 08:28 PM | #7 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
The front links are the same for all 3 models if im not mistaken...The rears are longer on the rubicon and honcho due to the longer wheel base but still 2 different sizes for the uppers and lowers...I gave up and just made my own..i got conflicting sizes for the same links from many different sources.
suspension links question - Similar Threads | ||||
Suspension links | IslandScaler | Axial Wraith | 5 | 10-05-2011 08:33 PM |
Uneven suspension links question..... | ToTheMAXXcrawler | General Crawlers | 3 | 01-08-2010 10:06 AM |
To use suspension links or not | pacman | Axial AX-10 Scorpion | 8 | 01-03-2009 03:05 PM |
Best way to do suspension links? | cj104 | Tools, and Procedures | 9 | 03-19-2008 10:46 PM |
Suspension links | RcBro | General Crawlers | 15 | 12-22-2005 10:40 PM |
