09-28-2013, 12:05 PM | #1 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
| BOOSTED's G6eep build
Now that Nationals are over, I decided to build another scaler, this one will more than likely fall into the class 2 area and be my g6 rig at the same time. I started with the scx10 wrangler kit, we all know what the box looks like, and the general build up so ill save you from those pics. I built the truck bone stock per the instructions and will be upgrading as I go. First think I switched out were the Icon shocks with proline scale shocks. The icons are great and super smooth, and more than likely will end up on my comp rig to replace the plastic scx shocks. Also in this pic you'll notice the body post, I hate body clips, so I took the posts and trimmed of the nipple and sanded them smooth, then drilled a 2mm hole down the center so I could use 3mm hardware to mount the body I won this 27t holmes torquemaster at nats and decided to use it at a starting point in this build Decided to stick with white for this truck, I also taped off all the hinges and hit those with spray in plasti-dip and well as the roof section. I picked up some led light bars from my buddy mark (Crawlerdad). I got his 6 1/2" bar made for the jk and his 2" bar both v2. These 2 together total just under 400 lumens To mount the 2" I used the small servo mounts from the kit. Drill through the front of the bar, and bam! Hood light. A small hole right behind the bar and routed the wires through the hood. To do the big bar I took the wire loom/clip pieces and trimmed off the back part like so Then lined em up and drilled to 1/16" holes to mount to the cage,and drilled 2mm holes in the end of the light bar and used pan screws to secure the bar. Then a hole in the corner of the windshield and one in the corner of the dashboard to route the wires between the windshield and cage to keep it clean. These lights are wicked bright! They're set to run at 11.1v(3s) and I plan on grabbing a couple more for this build. If you want some quality, water RESISTANT lights and a killer price hit up Crawlerdad he'll get you squared away I turned out all the lights in the house and shot these There are going to be ALOT of changes coming to this rig in the next few weeks and I will be updating this thread frequently Last edited by boosted4lyf; 09-28-2013 at 12:07 PM. |
09-28-2013, 12:17 PM | #2 |
| Re: BOOSTED's G6eep build
Ordered the Blue Monkey cms kit that should be here today or Monday, and will be throwing in a brxl and either a hitec 7995 or futaba 9157 for steering.
09-28-2013, 12:19 PM | #3 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Looking good! |
09-29-2013, 07:37 AM | #4 |
Looks good Steveo! Digging the white. It cool see how people use parts like you did for the light bar mount. |
09-29-2013, 09:59 AM | #5 |
Quarry Creeper Join Date: Jul 2013 Location: Meridian
Cool build subscribed
09-29-2013, 10:06 AM | #6 | |
| Re: BOOSTED's G6eep build Thanks guys Yes, yes it is. I just wish I had better camera, those pics don't do them justice Quote:
Thanks bud. Are in Meridian Ca? | |
09-29-2013, 11:00 AM | #7 |
Meridian, Idaho...Boise
09-29-2013, 11:09 AM | #8 |
If you looking for bright headlight lights they 1 watt. They also sell pre-wired 12v led's. High Power 1 Watt LED |
09-29-2013, 11:21 AM | #9 |
Thanks E, I was wondering what flashlight I was gonna rob for headlights. I bookmarked that page those things look badass. Do you run those?
09-29-2013, 11:33 AM | #10 | |
| Re: BOOSTED's G6eep build Quote:
Headlights Rock lights Tail lights 6" light bar Post up the blue monkey cms kit. I been looking getting it. Last edited by eric113; 09-29-2013 at 11:36 AM. | |
09-29-2013, 11:41 AM | #11 | |
As far as wiring I usually tie them all into a balance plug then plug them into the battery. I've also used that method with a small hidden push button toggle and it worked well. | |
09-29-2013, 04:37 PM | #12 |
Nice light bar mount. Going to have to steal that idea. My mounts just failed when I rolled my wraith down a hillside. You planning to sipe those tires?
09-29-2013, 04:41 PM | #13 |
Probably gonna sell em actually. Just gotta figure out what wheels I want TSS motoworx or??
09-29-2013, 07:11 PM | #14 |
Rock Crawler Join Date: Feb 2010 Location: in a Fishbowl watching time go by
Great idea for the Light mount! Also digging the plasti dip on the hinges makes them look a Lil more 3D. Thanks for sharing.
09-29-2013, 08:53 PM | #15 |
No sweat I enjoy sharing the small things, and thank you.
10-02-2013, 07:11 PM | #16 |
Looks tuff bruh. I reaelly like how you used the wire clips as a light bar bracket. very creative. |
10-02-2013, 07:27 PM | #17 |
Did you get you cms kit in yet ? Wanting to hear a pinions on it.
10-02-2013, 07:27 PM | #18 |
Thanks Trav, I have alot on deck for this build I just need the time to execute. Work has me away from this house about 2wks at a time so I pack what I can and work on it in my trailer when I'm not at work.
10-02-2013, 07:29 PM | #19 | |
Oh well as soon as I get it I will be posting up here with thoughts/advice. | |
10-02-2013, 07:39 PM | #20 | |
I have gunnar pins for the portals on JK and trans then Lockedup rc lockers to install. Sucks I'm middle of moving, aleast I will have my work bench back! | |
BOOSTED's G6eep build - Similar Threads | ||||
BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 | boosted4lyf | Axial AX-10 Scorpion | 297 | 10-16-2013 04:35 PM |
BOOSTED's 2014 build The 5th Dimension: MKII begins:pg 11 | boosted4lyf | EnRoute Berg | 239 | 10-10-2013 12:08 PM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
boosted's 2010 sss sportsman rig | boosted4lyf | Axial AX-10 Scorpion | 21 | 03-17-2010 08:44 AM |
