09-28-2013, 03:05 PM | #1 |
Newbie Join Date: Feb 2013 Location: UK
| honcho hot motor.
Sorted
09-28-2013, 03:46 PM | #2 |
| Re: honcho hot motor.
The common causes of over heating are:
Loosen the motor so the pinion doesn't touch the spur and see if the drive train turns freely. If you have binding remove the drive shafts one at a time to help locate where the binding is occurring. Use a piece of paper between the spur and pinion when you adjust the mesh so you don't have it too tight. |
09-28-2013, 09:05 PM | #3 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: honcho hot motor. Quote:
The bigger tires makes your motor strain more causing it to run hotter. A smaller tooth pinion will cause less stress on the motor and more capable of turning your larger wheels/tires. Im using a 17t with an 87t spur but running the 1.9 wheels/tires and its just about right.. Id try a 16t or smaller or another option is a larger spur gear. | |
09-29-2013, 12:07 AM | #4 |
Newbie Join Date: Sep 2013 Location: san antonio tx
Are the gears in the diff's and transmission the same as the wraith?
09-29-2013, 12:09 AM | #5 |
Quarry Creeper Join Date: Jun 2013 Location: Tacoma
Diffs are different. Wraith diffs came from the AX10. I think only a couple of parts are similar. I believe the transmission gears are the same.
09-29-2013, 12:28 AM | #6 |
Wraith, scx and ax all run the same diff and trans gears. Wraith trans has different outputs on the backside.
09-29-2013, 01:59 AM | #7 |
Cheers I think I'll try smaller pinion and check the mesh. How easy should wheels turn when checking for binding etc ?
09-29-2013, 02:52 AM | #8 |
Move the motor pinion away from the spur and check resistance, should roll easily.
09-29-2013, 05:47 AM | #9 |
Done that, with a good push it stops after 5 inches my other cars roll easier from memory( were away for the weekend
09-29-2013, 06:14 AM | #10 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
If memory serves me right... The 2.2 wheels have a deeper hex than the 1.9, so if you have 2.2 wheels on the 1.9 aluminum SCX hexes the wheels are likely rubbing in your steering knuckles. Sent from my highly abused iPhone using Tapatalk |
09-29-2013, 07:29 AM | #11 |
I'll have a look cheers
09-29-2013, 10:57 AM | #12 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
| Re: honcho hot motor. +1 same thing was happening to my bro in law do to offset of the wheels
honcho hot motor. - Similar Threads | ||||
My motor is getting hot...little help | pugs2300 | Electronics | 4 | 12-09-2011 07:00 AM |
Motor getting hot | pentec | Venom Creeper | 17 | 09-04-2011 02:18 PM |
RC Adventures - Hot Pink, Wet Honcho | RCSPARKS | Scale Videos! | 8 | 10-25-2010 06:36 AM |
How hot is too hot for the motor? | Mr. Ed | Losi Mini-Rock Crawler | 4 | 06-13-2010 11:09 PM |
motor temp - how hot is too hot? | wicked4x4 | Newbie General | 16 | 03-18-2010 09:49 AM |
