10-06-2013, 02:45 PM | #1 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
| Blue Monkey RC scx10 cms install guide
I received this kit the other day and figured since there weren't any straight forward install instructions I would give a little write up on how I did mine. I am not a BMRC team driver, or affiliated with them. This is just a friendly how to thread that hopefully will help anyone with questions. First off ill start by saying this kit is very beefy, the aluminum is very stout,comes pre threaded for 3mm hardware and the ti links are very nicely done. Tools I used: Needle nose pliers 2mm hex head driver Razor knife Hardware: 1:3x4mm screw 12: 3x6mm screws 2: 3x10mm screws 1: 3x14mm screw A handful of 3mm locknuts Upon arrival the kits looks like this First step: Remove bumper, both chassis braces,servo mount from axle the 3link mount and the receiver box. PLEASE NOTE IN THIS PIC I HAD THE MOUNT ON THE OPPOSITE WAY IT WAS SUPPOSED TO BE!! Nonetheless less, slide the mount in and secure the shock mounts to the chassis and cms mount with 2 3x6mm screws On the none panhard mount side of the chassis,secure the front shock mount with a 3x6 screw and locknut, then secure the front of the cms to the chassis with a 3x6 screw. Next pics: mount is facing the correct way On the panhard mount/servo side of the mount secure the front of the shock mount with a 3x4 screw and locknut. ( This is so it will clear the servo, I sanded down a 3x6 screw to 3x4) Next, to mount the panhard mount line up the holes with the mount and chassis. In the hole closest to the bumper you will use a 3x10 screw through the panhard mount into the cms mount. In the back hole I used a 3x6 screw and was abile to thread it through the hole In The chassis for a nice solid mounting point. Next secure the axle mount with 2 3x6 screws Then mount your servo using 4-3x6 screws NOTE: I had to shave 2 little nubs off the front off the servo case for it to sit flush, this is where the razor knife came in. Next you'll need 4 revo rod ends to make up the panhard bar and tierod Next mount the panhard bar(the short one) to the axle mount using the 3x14 screw and to the chassis mount with a 3x10 screw. Mount the tierod to your servo with a 3x10 screw and to the knuckle, the stock hardware should work here. Now: missed the pic but for the time being I am using the stock 3link mount, this is the point where I reinstalled it and the upper links I also remounted the receiver box using 2 3x6 screws at the cms mount and stock hardware at the chassis mounting points Not the greatest write up I know, but this should get you headed in the right direction. All in all I will be buying another kit for my next build this is a great product. Couple flex and drop out shots: |
10-06-2013, 02:46 PM | #2 |
| Re: Blue Monkey RC scx10 cms install guide
If have any questions let me know guys and I will try and help as much as I can.
10-06-2013, 03:04 PM | #3 |
Quarry Creeper Join Date: Aug 2007 Location: Bowling Green KY
Good right up and pics. I may have to pick one or three up myself..... Sent from tinker room pro |
10-06-2013, 03:22 PM | #4 |
RCC Addict Join Date: Feb 2012 Location: Ca.
Thanks for the write up, nice job. Have you tried it out yet?
10-06-2013, 03:31 PM | #5 |
No I should have the wiring complete tonight, and be able to try it out tomorrow
10-06-2013, 03:32 PM | #6 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Are the spacers out of the shock?
10-06-2013, 03:37 PM | #7 |
Spacers? Those are proline scale shocks with a single spring, ill post some pics with the icon shocks when I get home.
10-06-2013, 03:51 PM | #8 |
Steve, I think your missing mount on the axle for upper link ? Unless you didn't show it in your pics ? Does the nut on servo horn hit or rub on steering link at throw or compressed ? |
10-06-2013, 03:55 PM | #9 | |
| Re: Blue Monkey RC scx10 cms install guide Quote:
At full throw to the left( right if you're looking at pic.) the nut jut touches at full lock but that's cause the servo horn is plastic another horn that I can can run the screw up from the bottom to the horn will eliminate that | |
10-06-2013, 04:00 PM | #10 |
It look like to drag link hits frame.
10-06-2013, 04:23 PM | #11 |
It touches when the shock is fully compressed, I have no external limiting on the shocks.
10-06-2013, 04:29 PM | #12 |
| Re: Blue Monkey RC scx10 cms install guide |
10-06-2013, 05:19 PM | #13 |
They're 88mm and I was wrong, at full compression the panhard just touches the chassis the draglink has around 2mm of clearance, I think it was the angle I took the pic.
10-06-2013, 09:07 PM | #14 |
Pebble Pounder Join Date: May 2012 Location: Eastern Sierras
question! if you are running the VP Zero Ackerman High Steer Arms/Knuckles- do you need longer steering links or will the standard ones work? I see on the Blue Monkey site he offers the option for 8*knuckles- is this the option to choose if running standard zero ackerman high steer? RPP hobby does not offer that option for purchase |
10-06-2013, 11:25 PM | #15 |
Looks like the kit can install in either direction since yours looks to work, and the one in the BMRC thread is going the opposite way.
10-07-2013, 08:18 AM | #16 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Nice, will a servo winch drop right in next to the steering servo? Looks like it should, but the offset in the mount is throwing me off. I'm sure with my XR conversion I'll be making all my own links. Looks like a nice piece, might have to give it a look. |
10-07-2013, 10:05 AM | #17 |
| Re: Blue Monkey RC scx10 cms install guide I think the spool would hit everthing thats my .02 cents
10-07-2013, 10:08 AM | #18 |
| Re: Blue Monkey RC scx10 cms install guide The stock scx10 shocks are 90mm but with bump stop the are like 10mm big that put it at like 80mm so that means no flex.
10-07-2013, 10:14 AM | #19 |
It might, I think that's why BMRC was promoting the use of the the kmart winch. Ill toss a servo in,And see what it looks like as far as everything lining up
10-07-2013, 10:20 AM | #20 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
Looks like my setup..... Only issue I see with bmrc is the lower Panhard mount running beeftubes. There's not enough plastic to secure the lower mount with beeftubes in. Electronics tray: Panhard: |
Blue Monkey RC scx10 cms install guide - Similar Threads | ||||
Blue Monkey CMS kit | eric113 | Axial SCX-10 | 4 | 10-05-2013 06:43 PM |
The Blue Monkey Needs a Little Help !!! | Blue Monkey RC | General Crawlers | 19 | 04-12-2012 06:18 AM |
