10-07-2013, 11:26 AM | #1 |
Rock Stacker Join Date: Aug 2013 Location: St. Louis
| Got the shaft
I installed the ax2 2 speed tranny in my dingo. It raises the output shaft from the tranny and is creating some bind. Simple question, which after shaft has the most clearance? RC4WD Punisher MIP CVD Gmade/Junfac universal TMaxx 2.5 shafts (but I do not have a lathe) Thanks, I found lots of opinions about best quality in search but not which is most "flexible". |
10-08-2013, 11:29 AM | #2 |
| Re: Got the shaft
Thank you RC Sparks! 60+ views and not a single comment... "RC4WD Scale Steel Punisher Shaft (100-135mm) 5mm are my prefered option for the Honcho still very strong and can handle a slightly steeper working angle then either MIP or Junfac and the MIP wouldn't work with my axial spur cover." |
Got the shaft - Similar Threads | ||||
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
Jato shaft / yoke takes 5mm shaft? | Lunchboxer | Tamiya TLT Crawlers | 6 | 07-11-2006 11:05 AM |
