10-09-2013, 09:32 PM | #1 |
Pebble Pounder Join Date: Sep 2011 Location: Medford
| Matts scx10 action!
So Here is my scx10: Honcho wheel based Axial Aluminum C hubs STRC Knuckles Axial front Uni's STRC Rear lockouts Aluminum rear truss Gmade Transissions shocks RC4WD Beadlocks RC4WD TSL Boggers RC4WD IROKs RRP Metal trans gears MIP drive shafts Axial Light kit RC4WD CMS and Panhard kit custom aluminum links Castle MMP Castle CC Bec Novak Ballistic 13.5 brushless crawler motor JR 8911hv servo RC4WD Bulldog wireless winch And scale exhaust, scale accessories, custom aluminum tranny doghouse and custom aluminum battery tray relocation. It's first run when I got it: 1/8/14 Last edited by Matthewboerner; 12-08-2014 at 12:33 AM. Reason: Update |
10-10-2013, 10:16 AM | #2 |
Quarry Creeper Join Date: Nov 2012 Location: Nampa
| Re: Matts scx10 action!
i like the headers bro
10-10-2013, 11:15 AM | #3 |
| Re: Matts scx10 action! |
10-10-2013, 04:47 PM | #4 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
Looks good like the scale headers and tailpipe Sent from my SGH-I337M using Tapatalk 2 |
10-10-2013, 05:02 PM | #5 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
I like the exhaust! I'm actually planning on building an exhaust for a friend to run winch line through, and was thinking about Doing a 4-2-1 exhaust setup.
10-10-2013, 05:14 PM | #6 |
I'm going to be silver soldering the exhaust FYI
10-10-2013, 08:48 PM | #7 |
| Re: Matts scx10 action! That would be a good way of routing winch line. I should have thought about soldering them up! Maybe next run when I get my bending skills more tuned. You'll have to let me know when you get yours done.
10-10-2013, 08:52 PM | #8 | |
| Re: Matts scx10 action! Quote:
Here is a pic of my wraith | |
10-14-2013, 06:58 AM | #9 |
I had a chance to put some lights on the scx this weekend, they turned out good I think. I used the buckets as a template and a router and sanding bit on my dremel. It wasn't to bad. I used a hot glue gun to fasten the headlights in and the inner lights with the bulb holder screw. I also did this to the tail lights. So far so good. I think I might need better glue to hold the headlights in if a rock decides to poke them. And the flex shot haha |
10-14-2013, 09:23 AM | #11 | |
10-14-2013, 01:22 PM | #13 | |
11-04-2013, 06:23 PM | #14 |
So I got a brazing torch kit last week so I went to work on a new front bumper. It was my first time brazing, and I think it went well. I bought some brass plate and tubing and tubing bender springs from my LHS and then to Harbor Freight for the cheapy $6 tubing bender (which worked really well in conjunction with the springs) and away I went. I am wanting to do the next G6 that is close by, so I needed it to be winch friendly. I picked up the RC4WD Bulldog wireless keyfob winch today from my LHS. This thing is awesome! Anyway. I still need to make some mounts for the shackles I made out of 1/4" cotter pins and M3 hardwear. But here are some pics (paint is on the way) |
11-05-2013, 12:23 AM | #15 |
I'm also working on a drop bed for the c10 body. Its all cut out and ready to be glued back together. Just need to decide if I want to lay the shocks down or have them and the towers poke up into the bed. I'll post pics when it's done! I'm excited to put scale crap back there!!
11-05-2013, 08:16 AM | #16 |
Quarry Creeper Join Date: Aug 2013 Location: Colorado Springs
The light install is very clean..are those axial lenses and buckets? Good work!
11-05-2013, 05:26 PM | #17 |
11-06-2013, 08:58 PM | #18 |
I finished up my drop bed! So I used a lime green plastic container from the dollar tree, I would say its a pretty good fit. A little dremel action on the bed and container, I reduced the depth to 2.5 inches, sanded it, primed, and sprayed it black with a flat clear protective coat. I used shoe goo to fasten it to the underside of the bed rails. I used servo mounts and the stock body post the screwed them to a existing hole in the frame and tada! Oh I also trimmed out holes for the towers and shocks. (I didn't want to relocate the shocks) |
11-08-2013, 10:01 PM | #19 |
I tested out my bumper and winch today, worked great! Made a couple mods to it cuz the tires would rub at full lock and articulated. The only thing I was missing was a pull pal! So bam I made one! Last edited by Matthewboerner; 11-08-2013 at 11:16 PM. |
11-09-2013, 01:47 PM | #20 |
Here is an action shot from the back of my truck with some new rocks for my crawl area |
Matts scx10 action! - Similar Threads | ||||
Matts Wraith Action! | Matthewboerner | Axial Wraith | 59 | 10-09-2013 09:19 PM |
Matts Mini GC-3 *2011 Build* | MRCCRAWLER1.9 | Losi Mini-Rock Crawler | 32 | 02-10-2012 12:43 AM |
Green design/engineer matts?? | Arctic Fire | Newbie General | 2 | 12-04-2011 02:30 PM |
My SCX10 in action | fullspeeddesign | 1.9 Scale Rigs | 9 | 07-21-2010 09:48 PM |
SCX10 in Action........... | BENDER | Scale Videos! | 22 | 05-05-2009 06:21 PM |
