10-25-2013, 05:47 PM | #1 |
Newbie Join Date: Jun 2011 Location: Vienna
| Drive Shaft Rubbing 3-Link
Hey guys, got my SCX10 Rubicon RTR today. Nice Rig but after my first run I saw the drive shaft is rubbing the 3-Link suspenion in the front. So what should I do about it? I read somewhere else I could install 4-Link in the front too? Thanks for advice! |
10-25-2013, 05:52 PM | #2 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Drive Shaft Rubbing 3-Link
Im running the rtr as well but don't seem to have the rubbing issue you are having...therefore I cant comment on a fix but yes you can convert to a 4 link if you wanted. In the parts bag you get you will find a truss that looks like the one on the rear your links attach to on the rear axle...you use that to make your conversion..There are also the correct size links in the bag as well for the conversion..Not sure about hardware like nuts and bolts but the parts are there for the conversion. |
10-25-2013, 05:54 PM | #3 |
Rock Stacker Join Date: Jun 2013 Location: Wendell
All the rigs I've seen and had do rub a little on the Y link. I have upgraded to an aluminum 4 link and it has corrected my issues. Tho i dont think it really causes any major issue but I never liked how the original Y link connected to the diff anyways .
10-25-2013, 06:07 PM | #4 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
If you want to keep the 3 link, adjust the pinion angle down by shortening the spacer in the link on the side that is connected to the axle. Sent from my ZTE V768 using Tapatalk 2 |
10-25-2013, 06:23 PM | #5 | |
| Re: Drive Shaft Rubbing 3-Link Quote:
EDIT: just removed the spacer (AX80054) completely but not much of a difference. I'll probably switch to the 4-link sooner or later. So what is the difference in handling with 4-link to 3-link? Thanks! Last edited by soundmaster; 10-25-2013 at 06:41 PM. | |
10-25-2013, 06:43 PM | #6 |
I would just take off a little at a time till your driveshaft doesn't rub anymore..Try 1 or 2mm increments
10-25-2013, 08:43 PM | #7 |
4 link will be mit stable, and sturdy. I use 4link up front without a pan hard for my cms Sent from my ZTE V768 using Tapatalk 2 |
Drive Shaft Rubbing 3-Link - Similar Threads | ||||
stock 4 link binding problem and Drive shaft angle question, looking for your input | Tire for Hire | Axial SCX-10 | 19 | 09-04-2013 07:58 AM |
Driveshaft rubbing on my link? | crawling71 | Axial AX-10 Scorpion | 13 | 10-05-2011 10:41 PM |
Shaft rubbing issue | zjguy721 | Newbie General | 5 | 04-11-2010 01:18 AM |
Lower link VS Shaft drive kicking | loverichey | Team Losi Comp Crawler | 26 | 06-10-2009 04:20 AM |
Shaft Rubbing (not the good kind) | zjguy721 | Tamiya TLT Crawlers | 2 | 07-09-2006 11:46 PM |
