10-27-2013, 12:32 AM | #1 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
| What does everyone use to clean and keep your rigs looking new?
Just curious i use spray 9 and compressed air but not getting the results i need. Also whats a good spray lube that wont attract dust, dirt and sand?
10-27-2013, 12:48 AM | #2 |
| Re: What does everyone use to clean and keep your rigs looking new?
WD-40 that sucker before running it in the muck. Keeps everything shiny too
10-27-2013, 01:16 AM | #3 |
Rock Crawler Join Date: Apr 2011 Location: British Columbia
i have an old toothbrush, the more it gets gunked up the better it seems to work cleaning everything, and there is no better way to check for damage after a good beating then cleaning your rigs with a toothbrush |
10-27-2013, 03:19 AM | #4 |
Newbie Join Date: Oct 2013 Location: small town
WD-40 before you run it and after make sure to clean and lube the bearings up good especially the drive-shafts don't want it to get squeaky, I use 3n1 oil found at local wal-mart, hope this helps and I use a magic eraser for the body
10-27-2013, 09:23 AM | #5 |
Tried wd and hate the way the dust seems to be attracted by it. I run wd in the wet seasons but was wondering about a good dry silicon lube? Tried dry graffite spray but just makes an overspray mess.
10-27-2013, 10:39 AM | #6 |
Quarry Creeper Join Date: Jul 2013 Location: Salem/Portland
#1 compressed air #2 a toothbrush #3 disassembly and using toothbrush #4 ALWAYS CLEAN YOUR TIRES AFTER U USE THEM I WASH THEM WITH SOAP AND A TOOTHBRUSH IT WILL KEEP YOYR TIRES NICE AND SOFT DIDN'T BELIEVE IT AT FIRST WHEN I WAS TOLD ABOUT IT BUT IT WORKS WONDERS |
10-27-2013, 10:54 AM | #7 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
take it to the self serve car wash. if your tires/wheels are vented you might want to clean them by hand
10-27-2013, 10:56 AM | #8 |
RCC Addict Join Date: Mar 2009 Location: Chilton
scrubbing bubbles let it sit for a min then rinse it of good. If its really nasty rinse it really good before the scrubbing bubbles. Then I go through and lube it all up with corrosion x and motorcycle chain wax. It works good its water proof doesn't attract dirt and it doesn't sling off. |
10-27-2013, 11:24 AM | #9 |
150psi
10-27-2013, 01:13 PM | #10 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: What does everyone use to clean and keep your rigs looking new? Same here. I just take them to work and use a non-OSHA-approved air gun. I don't worry too much about things rusting. I'm prepared to replace screws and what-not, when they get too bad; so I don't worry too much about lube. I do have a bit of marine grease in areas that see more movement (u-joints, driveline slip sections, axles, etc), though. That seems to be preventing them from corroding, so far. My Slash on the other hand, gets cleaned with a water hose! It plays in mud so I don't keep it exceptionally clean, anyway. I do need to upgrade it to stainless hardware, though. |
10-28-2013, 09:22 AM | #11 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
eezox is a gun lube that drys and protects from corrosion. it comes in a spray but it puts out WAY WAY more then is needed. if you can find it in the needle dropper I'd get that. not sure how it holds up to being submersed but it holds up to pretty good to rain and mists and takes the abuse of a gun. I've used it on my drive shafts to keep them from squeaking without collecting dust, usually lasts a few weekends (with 10-15 hours driving on the weekends, the kids love this thing) before they start squeaking. warning, the crap smells bad, use only outside or in exhausted areas. I sprayed it in my bedroom with good ventilation ( 2 windows in the wall and one in the roof) and it was 3 days before I could sleep there again. I want to give the chain wax a try when I get to it. |
10-28-2013, 09:27 AM | #12 |
I use mud to keep mine looking fresh. Do NOT gt WD40 on your tires! |
10-28-2013, 09:33 AM | #13 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
your supposed to clean these things???? lol |
10-28-2013, 10:34 AM | #14 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
One tip... Don't use straight Simple Green on the lexan parts. Screwed up and did that on me and my son's Wraiths. Within a week both bodies started coming apart. I blame the Simple Green for making the lexan very brittle. |
10-28-2013, 12:25 PM | #15 |
Newbie Join Date: Oct 2013 Location: 35°37′58″N 139°52′50″E
1 inch paint brush with a rubber band kinda close to the tip and compressed air... i've even used a leafblower once cause i needed to knock the sand outta it in a rush.
10-28-2013, 01:48 PM | #16 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
I bought a used rig off NissanDriver a few weeks ago, thing was one of the cleanest used rigs I've ever seen == he said he uses Dawn soap and a toothbrush on all his rigs after every run. Definitely got that sucker looking as clean as a new RTR out of the box. All I've ever done in the past was give a wipe down with a wet towel and use air compressor in the nooks and crannies -- soap and toothbrush will be my new method as long as the rig has been waterproofed.
10-28-2013, 04:48 PM | #17 | |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
| Re: What does everyone use to clean and keep your rigs looking new? Quote:
I sometimes wish I could leave my rcs dirty but my ocd nature doesn't allow me to be like that. But keeping things clean is a good way to make things consistent. | |
10-29-2013, 08:45 AM | #18 |
Thanks mike. Yeah, that rig was ridiculously clean. Now not so much |
10-29-2013, 11:56 AM | #19 | |
but the brush bristle's are stiffer and need no rubber band. I do not use chemicals for cleaning... just water generally... sometimes a little dish soap added. Most of my undercarriage is scuffed/scarred up... so bling clean ain't gonna happen anyways. | |
What does everyone use to clean and keep your rigs looking new? - Similar Threads | ||||
What do you guys use to "clean" your rigs? | LowLock | General Crawlers | 18 | 08-09-2011 03:53 PM |
