10-27-2013, 10:30 AM | #1 |
Rock Stacker Join Date: Dec 2012 Location: canada
| Powerfull dingo , 2 speed, big motor THIS IS THE BEAST!!! 2.2 RIPSAW AND DROOP SETUP !!! REAR SUSPENSION 3 LINK HOMEMADE PANHARD FIRST FULLY COMPRESS MAX EXTEND AND REAR SWAY BAR FOR HI SPEED BASHING AND NOWTHE FRONT SUSPENSION WITH 3RACING PANHARD AND SWAY BAR,,, THE SWAY BAR WITH QUICK DISCONNECT THE MOTOR IS 700 SIZE A BETTER VIEW OF QUICK DISCONNECT AND MY FAVORITE PART 700 MOTOR RUN ON 3 CELL ,IS COUPLED DIRECTELY TO A SUMMIT TRANSMISSION BY A AXIAL DRIVE SHAFT!!! i CUT THE INPUT SHAFT FOR FIT THE DRIVE SHAFT NO MORE SPUR GEAR, THE MOTOR IS SITIN THE 3 RACING PANHARD MOUNT THIS SETUP GIVE ME A VERY GOOD LOW END TORK WITH AMAZING PUNCH IN FIRST GEAR, AND MABEE 50 KM/H IN 2 ND GEAR !!!!!! YESTERDAY I SMOKE A SUMMIT VXL DIFERRENT VIEW OF THE DRIVE LINE I HOPE THATS WILL GIVE SOME IDEA !!! MABEE WITH BRUSHLESS 500 KV MOTOR , OR I THINK WITH A DEWALT 20 V MOTOR CAN BE FASTER AND STRONGER !!! I REALLY RECOMMAND THIS SETUP, NO LOST JUST GAIN !!! I THINK IT'S EASIER TO MADE WITH RC4WD AX2 TRANSMISION,WILL BE IN MY NEXT BUILT |
10-27-2013, 01:24 PM | #2 |
Rock Stacker Join Date: Mar 2013 Location: Vinton
| Re: Powerfull dingo , 2 speed, big motor
I really like this rig! I run a AX2 trans in mine and the versatility of the 2 speed is awesome. Can you give me a lil more info on the 700 motor? I'm currently running a Tekin 17.5 turn 2500kv motor in mine. At 9lb 6oz I need more bottom end though. Maybe run 3s or go with a Roc412. What do you think? |
10-28-2013, 11:07 PM | #3 |
this is a drill motor 5 mm shaft, but the next motor i will put is a dewalt 20v . |
10-28-2013, 11:08 PM | #4 |
10-29-2013, 08:37 AM | #5 |
Pebble Pounder Join Date: Jun 2009 Location: Canada
I like the short cab dingo. Might have to do this on mine!
11-14-2013, 08:11 AM | #6 |
| Re: Powerfull dingo , 2 speed, big motor |
Powerfull dingo , 2 speed, big motor - Similar Threads | ||||
speed weigand camper / Dingo | hotwheels000 | Scale Accessories | 19 | 03-10-2014 09:03 PM |
twin hammer 2 speed into a dingo | m1009cucv | Axial SCX-10 | 16 | 10-07-2013 11:26 AM |
most powerfull brushed motor when limited to 7,4 volts | murky123 | Axial SCX-10 | 16 | 03-11-2011 04:33 PM |
big speed | romulus22 | Non Crawler RC's | 20 | 05-14-2010 01:20 PM |
powerfull super... | pitass | Tamiya Clod Buster | 19 | 09-15-2009 08:26 PM |
