10-28-2013, 07:36 PM | #1 |
Newbie Join Date: Oct 2013 Location: Calgary, Canada
| Wheels "stuttering" ...where to start? Video inside...
Hey all, I built and replaced my links. My rear links were replaced a few days ago and all was well. I replaced my front links (converted to 4 link) and today I have a stuttering in my wheels. (See video below) I am not sure that it has anything to do with my links at all. I DID have my motor pinion gear come lose the other day so I took apart the gear box and tightened it down and added loctite. While tightening down my pinion I noticed a bit of play in the main gear. (It moved forward and back slightly) Any ideas? Thanks! Greg HERE is the video of the issue: Scx10 transmission issue? - YouTube |
10-28-2013, 07:46 PM | #2 |
Pebble Pounder Join Date: Jul 2011 Location: On the trails
| Re: Wheels "stuttering" ...where to start? Video inside...
Can't tell by the vid, could be your lower links are a bit too long and have your drive shaft in too much of a bind. Try shorting your lowers a bit which will pitch your axle up a bit.
10-28-2013, 07:50 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
If you separated the driveshafts, maybe you didn't align them correctly before reinstalling?
10-28-2013, 07:54 PM | #4 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Thiers 2 little raised lines on the driveshaft halfs,,,,those must be lined up with each other or it will cause a stuttering effect in the drivetrain. I created that same problem before and lining the marks up fixed the problem |
10-28-2013, 08:10 PM | #5 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
i have the same problem after installing my MIP driveshafts
10-28-2013, 08:51 PM | #6 | |
| Re: Wheels "stuttering" ...where to start? Video inside... Quote:
Thanks for helping all. Greg | |
10-28-2013, 09:10 PM | #7 |
| Re: Wheels "stuttering" ...where to start? Video inside... I tried Integy shafts and could only get one to work right..I just went back to stock drive shafts. you can strengthen the stock shafts and they should handle all but the most powerful motors using a 3s battery or better. Last edited by 6sharky9; 10-28-2013 at 09:13 PM. |
10-28-2013, 09:13 PM | #8 |
i think you are running stock driveshafts i have the MIP's on my Honcho searching the net and found that the MIP kit i got 10145 creates a bit of an issue on the Honcho....Im running the proline shocks, I need to get the angle of the axles to point more towards the transmission to avoid the same stuttering as the OP was getting |
10-30-2013, 03:24 PM | #9 | |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
Thanks guys, taught me to READ the manual properly... | |
10-30-2013, 03:53 PM | #10 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Your lower links are too long. Angles on the drive shaft look too sharp. Lengthen your upper links or shorten your lowers. That will fix the problem. Take some pics of it sitting on the wheels. So we can see the drive shaft angles. |
10-30-2013, 06:29 PM | #11 |
| Re: Wheels "stuttering" ...where to start? Video inside... |
Wheels "stuttering" ...where to start? Video inside... - Similar Threads | ||||
Jeep WK "Grand Cherokee" SCX10 - Episode 1 "Rescuing Megan" - Full Video | Spidernad | Scale Videos! | 4 | 11-12-2012 11:23 AM |
