10-30-2013, 03:27 PM | #1 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| WB help
I just got a scx10 chassis in a trade and want to use it instead of my Reign K2-5 chassis. I was wondering what length links I'd need for a 12.25 inch wheelbase so I can put my Bronco body on. |
10-30-2013, 04:28 PM | #2 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: WB help
A link set for a honcho or rubicon unlimited which are for a 12.3 inch wheel base and just file the ends a little for your exact body fit. Being a difference of .02mm just file .01mm off each end. or if you want to make custom links youll have to mock up where you want the axles to fit on the chassis/body and make the proper lengths Last edited by 6sharky9; 10-30-2013 at 04:35 PM. |
10-30-2013, 04:32 PM | #3 |
| Re: WB help
All I need is the links. I think the lowers are 106mm, but have no idea what length the uppers are. Maybe 98mm? I just need to know the length.
10-30-2013, 04:37 PM | #4 | |
| Re: WB help Quote:
but keep in mind it will just show the tube length and not actual full length eye to eye of the link ends..they might list the length of the ends but don't recall. | |
10-30-2013, 05:06 PM | #5 |
| Re: WB help
So, so far I've found out the front lowers are 98 mm and the rears are 106mm. Now I just need to figure out how long I need to make the uppers. |
10-30-2013, 05:17 PM | #6 |
| Re: WB help
Try the axial manual you can find on the internet |
10-30-2013, 05:28 PM | #7 |
| Re: WB help That's exactly where I got it from. I did a little searching on here too and found a thread that had a honcho with a 12.3" wheelbase that was being lengthened. He had the original link lengths which are: Front uppers-90mm Front lowers-98mm Rear uppers-98mm Rear lowers-106mm |
