11-08-2013, 10:33 AM | #2 |
| Re: 3s racing High Clearance Knuckle
search "portal" others have used/installed portals. ie: eric113's Portal axle JK can't say as to that specific product tho'... I don't want to run more moving parts that wear out... I prefer to keep it simple. Last edited by TacoCrawler; 11-08-2013 at 10:37 AM. |
11-08-2013, 12:10 PM | #3 |
They are alot of work to get installed and to make them last.
11-08-2013, 12:17 PM | #4 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
been out of stock forever i want to put a set on some mrc axles. |
11-08-2013, 12:54 PM | #5 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
ok what needs to be done to make them last? thanks
11-08-2013, 01:06 PM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
I just took at look...what the hell does that big ass thing do for the front axle?
11-08-2013, 01:17 PM | #7 |
| Re: 3s racing High Clearance Knuckle If you plan on running cvd's the stub shaft needs to modded, I run traxxas stub axles for the portal stub axles don't have to, they will also need to be modded so unless you have mill and lathe or know someone that has them. What are you talking about ? |
11-08-2013, 01:22 PM | #8 |
gives you more clearance. no lathe here
11-08-2013, 01:30 PM | #9 |
| Re: 3s racing High Clearance Knuckle These: 3racing High Clearance Aluminum Knuckles Axial AX10 SCX10 Scale Rock Crawler If this is what your all talking about. I don't understand the purpose of these. |
11-08-2013, 01:32 PM | #10 |
Oh ok I got it now. It relocates the drive axle so there's more clearance for the housing.
04-13-2014, 08:47 PM | #11 |
Rock Stacker Join Date: Jul 2013 Location: South Bend
Any knowledge on these? anyone run them? me and my buddy are thinking about going halfnhalf on these to run just on the front and then lift the rear to level the truck....
04-21-2014, 02:46 PM | #12 |
[QUOTE=MichianaRCcrawlers;4744405]Any knowledge on these? i would say save your money |
3s racing High Clearance Knuckle - Similar Threads | ||||
New 3racing High Clearance Knuckle. | QIK-RX4 | Axial AX-10 Scorpion | 127 | 07-14-2014 05:42 PM |
Show me your high clearance knuckle setups | Jus | Axial AX-10 Scorpion | 12 | 02-20-2011 12:24 AM |
high clearance knuckle | saturnsl89 | Tamiya CR-01 | 7 | 01-12-2011 04:33 AM |
Axial High Clearance steering knuckle | volvoc304 | EnRoute Berg | 10 | 04-19-2010 04:04 PM |
high clearance tlt knuckle | sloppy | Tamiya TLT Crawlers | 11 | 11-15-2007 09:16 AM |
