11-14-2013, 10:38 AM | #1 |
Rock Crawler Join Date: Mar 2010 Location: Las Vegas
| Axial Jeep Wrangler G6 - Renegade
A little about what I have planned for the new Axial Jeep Wrangler G6 kit. If you have seen my builds before you know I like the factory looking stuff for the most part. With this dovetailed newer body style rig, I want to go Retro. Bringing a mix of the Golden Eagle and Renegade jeep back. Overdrive gear up front, of course metal gears in tranny. Still up in the air about running a dig unit or not. Wanting to go Brushless. So watch for motor ESC combo. Will be running Mayhem Engineering Wheels. Trying a new set up on the steering I have never run before, but it seems to work. Stay tuned for the ride and we will see how it all turns out. http:// http:// http:// http:// |
11-14-2013, 10:51 AM | #2 |
| Re: Axial Jeep Wrangler G6 - Renegade
I picked up my custom paint masks here in Vegas today from RC Paint Masks and vinyl A.K.A B.A.D. Graphix B.A.D Graphix http:// Last edited by Rivas Concepts; 11-14-2013 at 11:12 AM. |
11-14-2013, 12:34 PM | #3 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
Nice can't wait to see more
11-14-2013, 01:13 PM | #4 |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
I see the Orange JK I built in your background Can't wait to see what you have in stored.
11-20-2013, 05:42 PM | #5 |
This build is taking a while because I am also building it on Rivas Concepts Garage. Some updates: ALL axial aluminum upgrades and Beef Tubes http:// Awesome Las Vegas Tour, Tekin electronics Rivas Concepts Gagrage Ep-3 - YouTube |
11-20-2013, 11:24 PM | #6 |
Pebble Pounder Join Date: Aug 2007 Location: Switzerland
I think this is gona be a great built. Looking forward to the paint. What is the AX10 Locked Transmission set AX30487 for? Is there something in it you don't allready get with the kit? Cheers Rene |
11-21-2013, 08:12 AM | #7 |
| Re: Axial Jeep Wrangler G6 - Renegade I am looking forward to painting it too.! I went with the locked transmission to eliminate the slipper clutch. The kit comes with a standard transmission with the slipper clutch, and I will me doing AX30708 metal gear set in the trans.
11-21-2013, 08:18 AM | #8 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
hmmm..i bet you get yours finished before parker does... |
11-21-2013, 08:23 AM | #9 |
For those of you who dont know about beef tubes, here is a simple run down. I like them because they keep your weight down low, where you need it most. They also make plastic axle housings stronger. Inexpensive alternative to aluminum axles. However they do not just drop right in. You have to clearance the inside of plastic housing. New plastic housing http:// http:// http:// A dremel tool and a sanding or grinding stone. http:// http:// |
11-21-2013, 08:41 AM | #10 |
Axial aluminum C hubs, knuckles and also using CVD's. They work for my driving style and I really need them for steering set up. If you look at pics you will see. YES I know knuckles are on backwards. Its because I am running and Austrian steering tuning kit. Its kind of like BTA, but not quite. Check it out.. I learned about this set up from Austrian Danile Siegl. http:// http:// This Kit is designed for high steer, but I am making do for right now. http:// http:// http:// http:// |
11-21-2013, 10:25 AM | #11 | |
Rock Stacker Join Date: Jun 2005 Location: Philadelphia
| Re: Axial Jeep Wrangler G6 - Renegade Quote:
11-21-2013, 10:43 AM | #12 |
| Re: Axial Jeep Wrangler G6 - Renegade These are PLE Engineering or Sumquak here on RcC. These work with the stock axles. I used CVD's because of the steering set up I used. Beef tubes work with a bone stock set up. Nothing needed, except to clearance the inside of plastic housings. Hope this helps.
11-21-2013, 10:45 AM | #13 | |
I'll look 'em up thanks! | |
11-21-2013, 11:18 AM | #14 |
Interesting steering link. Never seen one setup like that before.
11-21-2013, 12:52 PM | #15 |
Quarry Creeper Join Date: Jun 2010 Location: Vienna, Austria
Hi, The steering setup is from an Austrian Company called "Trial and Fun". You might need to shave of the "leave" mounts a little bit if you run the adjustable C-Hubs. Cheers Daniel |
11-21-2013, 01:29 PM | #16 |
RCC Addict Join Date: Jan 2006 Location: Irritable Isle
Kinda want that steering link.
11-21-2013, 02:44 PM | #17 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
You could have just bought the AX80009 parts tree if you wanted an extra spur gear lockout, no need to waste even more money on a complete locked out tranny. | |
11-21-2013, 05:55 PM | #18 |
Rock Crawler Join Date: Aug 2012 Location: Los Angeles, CA
Rivas, I look forward to seeing your Jeep vision come to fruition. |
11-21-2013, 10:05 PM | #19 | ||
It goes for around $50, Ill post link in a few. Quote:
Thanks, I am excited to get it done.! | ||
11-21-2013, 10:23 PM | #20 |
Little more progress today. Rpp Hobby already has these Wrangler G6 kits for sale and shipping tomorrow. I am still building, but I am on the body, part I really like about building. Axles done, Beef Tubes in front & rear with overdrive gear upfront. http:// Axial Ax10 locked out trans with Axial Metal Gear set. http:// Mayhem Engineering Monsters with TrailReady beadlocks, Crawler Innovations dualstage foams 4.50 and the Maxxis Trepadors. http:// |
Axial Jeep Wrangler G6 - Renegade - Similar Threads | ||||
Axial Jeep Wrangler G6 Kit | DRIVNMF | Recon G6 | 25 | 11-04-2013 09:11 AM |
Jeep JK Wrangler (Axial) Build | brazwewn | 1.9 Scale Rigs | 18 | 01-20-2013 11:03 AM |
New Axial SCX10 Jeep Wrangler Unlimited Rubicon Axial Promo Vid | B94Cast | Scale Videos! | 0 | 10-30-2012 12:20 PM |
taiyo Renegade jeep | zumzum5150 | Chit Chat | 2 | 06-25-2007 01:16 PM |
