11-21-2013, 01:01 PM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
| GTB2 in an SCX10, need motor suggestions! Won a GTB2 awhile back, and I want to put it to use for a change. I know it's for short course, but it was free, and it's my only real alternative since my AE-2 ESC fried. (it beeps, refuses to bind, and causes the servo to start twitching erratically) I'm Mostly doing Trail driving, maybe a rock pile or two but nothing too crazy. I'm under a tight budget (under $50) and trying to find a good trail brush less motor I'm leaning towards Turnigy TrackStar 21.5T Sensored Brushless Motor 1855KV currently Also, what spur/pinion setups work with this setup? Any advice would be awesome! Thanks for looking! Last edited by Intashu; 03-21-2014 at 11:07 AM. |
03-21-2014, 11:09 AM | #2 |
| Re: GTB2 in an SCX10, need motor suggestions!
Well my AE-2 fried I think, so it's time to start looking at using that GTB-2 again. I know it isn't the best option, but I think it will be alright for trail riding once set up right. |
03-21-2014, 11:17 AM | #3 |
Newbie Join Date: Dec 2009 Location: Wildomar
I run a novak 13.5 on my gtb2, I run 90/15 gears, top speed of 5 mph and will climb over anything. I feel it is a great balance between low speed control and wheel speed when you hit very loose dirt and need that extra power. Oh and I just ran 8 hours and 5 minutes on a single MaxAmps 8000 mah pack 5 days ago on a rough trail on that set up and everything worked great. |
03-21-2014, 01:41 PM | #4 |
High speed motor with low gearing? I assume at that long of a run time your motor isn't burning a hole through the truck. I always figured lower was the way to go for trail trucks... I'll have to look into the gear changes however thanks!
GTB2 in an SCX10, need motor suggestions! - Similar Threads | ||||
suggestions on using a GTB2 in a SCX10? | Intashu | Axial SCX-10 | 0 | 04-06-2013 05:37 PM |
Motor suggestions? | solomon7 | Electronics | 5 | 01-18-2008 11:41 AM |
