11-25-2013, 03:35 AM | #1 |
Newbie Join Date: Sep 2013 Location: israel
| Gmade zero 104mm are they good and fit?
Help I have the scx10 dingo and I want to replace the stock shocks. Is the gmade zero 104mm are good for my dingo? https://www.ckrccrawlers.com/gm20201...mm-p-4352.html I also have the level3 lift http://level3rc-store.com/axial-scx1...t-kit-p-9.html Eldad iPad " Tapatalk |
11-25-2013, 03:59 AM | #2 |
Newbie Join Date: Aug 2013 Location: Mesa
| Re: Gmade zero 104mm are they good and fit?
The 104mm length will be to long, especially with your level 3 lift kit. But I believe you can flip it upside and mount the shocks higher up than what you would normally be able to on the shock hoop giving you a droop setup. This way the 104mm would be perfect and you would get lots of articulation. The g-made shocks I hear are good and do great bashing and high speed trail runs, also you have the ability to run different springs, I find them to look a little on the big size diameter wise for the scx10. The king rc4wd shocks are more scale and thinner, look like the go perfect on an scx10 with dual springs but I find them even with 50wt to not be enough spring or oil capacity for bashing or high speed, but boy do they look great and work great for low speed rock crawling.
11-25-2013, 11:50 AM | #4 | |
Quarry Creeper Join Date: Jul 2013 Location: Salem/Portland
| Re: Gmade zero 104mm are they good and fit? Quote:
11-25-2013, 01:08 PM | #5 |
Pebble Pounder Join Date: Oct 2005 Location: Noblesville , IN
I run the 103 piggy backs on Blue and like them. I think they look good on there.
Gmade zero 104mm are they good and fit? - Similar Threads | ||||
G Made Zero 104mm Setup | Robert51483 | Axial Wraith | 3 | 11-14-2013 05:54 PM |
Gmade zero 94mm shocks any good? | Rckhrse | General Crawlers | 2 | 03-05-2013 07:53 AM |
Which lipo would be a good fit for Novak goat 3s? | strungoutt1 | Newbie General | 7 | 04-22-2011 08:32 AM |
Ultracs on Gmade Wheel both narrowed...any good? | TheHeadHunter | Tires and Wheels | 5 | 02-26-2008 08:42 PM |
