11-11-2017, 03:37 PM | #2461 |
Newbie Join Date: Aug 2017 Location: Canada
| Re: What did you do to you SCX-10 today?
Finally installed some aluminum suspension links for extra stability!
11-25-2017, 03:42 PM | #2462 |
Newbie Join Date: Feb 2017 Location: Huntington Beach
I added brass tubes in the rear inside the SSD axles. Adding weight down low.
11-28-2017, 07:20 PM | #2463 |
Rock Crawler Join Date: Dec 2016 Location: Minnesota
Took delivery of 2 more. Sent from my SM-G930V using Tapatalk |
12-06-2017, 11:22 AM | #2464 |
Newbie Join Date: Nov 2011 Location: Imperial
I quit being lazy and installed tires on my wheels to text flex for no tire rub, bub. |
12-07-2017, 08:29 AM | #2465 |
Pebble Pounder Join Date: Feb 2015 Location: Kansas city
Got new shocks put together and installed. |
12-09-2017, 01:17 PM | #2466 |
Quarry Creeper Join Date: May 2017 Location: Devon
| Re: What did you do to you SCX-10 today? Installed the awesome Promodeller 470 |
12-15-2017, 12:13 PM | #2467 |
Rock Stacker Join Date: May 2013 Location: Appalachia
Installed a Hitec HS-7950-TH steering servo. Installed Hot Racing servo mounting clamps.
12-15-2017, 06:26 PM | #2468 |
Newbie Join Date: Aug 2014 Location: Highland
I decide to part out my G6 to go all in on a Bomber/scx10 build. Tons of Integy parts including a steel "tube" chassis BUT I want to shorten the wheelbase and use SCX10 axles. And by that I mean two front Integy axles from Amazon. So geeked for rear steering. We will see how well the drivetrain fits the chassis, including the two-speed tranny. I want the SCX10 axles because they are more scale in size. Might end up chopping off the rear spare tire mount since it will really stick out if I shorten the wheel base. I'm thinking of posting the build. Can't wait. first batch of parts ordered today. Merry Christmas to me! |
12-16-2017, 09:06 AM | #2469 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
I added a pair of Crawler Designs low profile rear shock towers. These will allow you to use the LC70 without relocating the shocks or cutting holes for the shock towers. |
12-17-2017, 09:44 AM | #2470 |
Installed Pitbullt Rock Beast II 2.2” tires Installed ProLine Faultine 2.2” beadlocks Installed Tekin Pro4HD 2500KV. Tuned MMP. |
12-24-2017, 07:31 PM | #2471 |
Newbie Join Date: Oct 2017 Location: US
XR10 Narrow Mod on blue and new 100mm shocks...gave purple to my daughter for christmas Sent from my SM-N950U using Tapatalk Last edited by dtylereagle; 12-29-2017 at 07:27 AM. |
12-26-2017, 01:04 PM | #2472 |
Quarry Creeper Join Date: Nov 2013 Location: Omaha
New body, tires and wheels for the boys rig Sent from my iPhone using Tapatalk |
01-04-2018, 08:09 AM | #2473 |
Newbie Join Date: Nov 2017 Location: Greenville
Picked up a used set of Trepadors with wheels to replace the original dry rotted tires it came with, then took it out into the first big snow we've had in years... Yay! Sent from my HTC6525LVW using Tapatalk |
01-16-2018, 08:03 PM | #2474 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
Added the flux capacitor to the C MOG ... Sent from my iPhone using Tapatalk |
01-18-2018, 07:01 AM | #2475 |
| Re: What did you do to you SCX-10 today? Ordered this yesterday, next on the list is SSD's front end kit and chassis mount servo..and proper front cvd's (I have an original Honcho, with dogbones..ugh) |
02-25-2018, 04:28 PM | #2476 |
Added some 6mm SSD hubs all around. Hyrax's were rubbing links and shocks/springs on both sides, well before maxing out the servo, knuckles or VVD's. Sent from my SM-G930V using Tapatalk |
05-06-2018, 03:54 PM | #2477 |
Rock Crawler Join Date: Sep 2015 Location: Lake Stevens
Swapped in a set of LockedUp RC OTVD front axles; decided I needed something stouter after breaking/rebuilding a set of Axial Scorpion universals 3x times (kept shearing the small pin)! The OTVDs are awesome and use beefy/stout hardware. I’m guessing they’ll last forever. Some slight sanding on the inside of my Vanquish Stage-1 C-hubs to make them fit, but a drop-in install otherwise. I was nervous about sanding the C-hubs due to the blue anodizing, but the sanded surfaces are not visible with the axles installed and it was an easy 10 min operation with a file. Sent from my iPhone using Tapatalk Pro |
05-06-2018, 08:17 PM | #2478 |
| Re: What did you do to you SCX-10 today? |
05-08-2018, 12:52 AM | #2479 |
Rock Crawler Join Date: Apr 2011 Location: British Columbia
05-12-2018, 05:55 PM | #2480 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
Working on a new body.. Sent from my SM-G930F using Tapatalk |
What did you do to you SCX-10 today? - Similar Threads | ||||
scx cherokee and my f100 scalin today.... | josh97 | Axial SCX-10 | 2 | 08-28-2011 04:55 PM |
Ogt my scx 10 tr today | scaleerdad | Axial SCX-10 | 2 | 10-15-2009 09:44 PM |
