Thread: Axial G6 link length
Old 12-06-2013, 04:11 PM   #1
Default Axial G6 link length
I just purchased the axial G6 body for my scx10 chassis and need the rear link lengths upper and lower if anyone has one and can give an eye to eye length that would be much appreciated.
bagged86 is offline   Reply With Quote
Old 12-06-2013, 07:16 PM   #2
Default Re: Axial G6 link length
115mm for uppers, 122mm for lowers measured from the middle of the eye to middle of the eye. At least that what I got.
Hirschowl is offline   Reply With Quote
Old 12-06-2013, 07:59 PM   #3
The kit comes with 98mm lower links and those plastic uppers front & back. I replaced the plastic uppers with axial 91mm tubes & axial rod ends & achieved a good pinion angle.
txbart is offline   Reply With Quote
Old 12-06-2013, 10:28 PM   #4
Thanks for looking into that I called Axial and they don't even seem to know how long they are yet.
Old 12-07-2013, 11:47 PM   #5
You can always download the kit instructions and the different aluminium link set instructions and cross reference everything to get the correct link lengths!
The G6 has the same front and rear link lengths which is the same as the 12.3 front links found on the honcho and jeep wrangler........so the uppers are 2x 7x60mm plus 2x 7x25mm, that is for a 4 link front and rear. The lowers will be 98mm in length! !!
mr lee is offline   Reply With Quote
Axial G6 link length - Similar Threads
4-Link upper link length? TNT1 Axial SCX-10 0 09-28-2012 03:07 AM
upper link length for honcho with 4-link truss 2500hdon37s Axial SCX-10 19 08-04-2012 08:46 PM
Link length - UGC Viper, axial uppers avoidsthelight Axial XR10 6 03-24-2011 11:06 AM
3 Link 4 Link length question squad2man HPI Wheely King 4 03-05-2010 07:56 AM
Axial machined Hi-clearance lower link length? BigB_117 Axial AX-10 Scorpion 3 07-11-2009 04:42 PM
