Thread: 4 Link Set Up Help
Old 12-07-2013, 02:17 PM   #1
Default 4 Link Set Up Help
Hi guys
Been trying to dig through all these great posts and threads but I am still lost. I have a SCX10 its basically still all stock. I picked up a FR & RR set of DMG 4 Link Truss's sometime ago. I am pretty sure I got the Rear End figured out, installed correctly etc.. Now onto the front.. I am having some problems figuring out how to get the 4 link to install and set up. I am thinking that I might need to order a steering servo relocation kit like the Hand Brothers CMS but from what I can tell they aren't made any longer??
What other options are out there if I need this servo relocation kit? As of right now my steering servo is in the stock location??
Any help, links to threads, & pictures would be awesome..
Thanks for all the help guys..
monsterman is offline   Reply With Quote
Old 12-07-2013, 02:23 PM   #2
Default Re: 4 Link Set Up Help
If you have a kit SCX10, there should be a four link upper mount in the box. If not, Blue Monkey makes a combo servo and four link mount. I have one on my Honcho and Rubicon. EDIT. this will still mount your servo on the axle however.
raceeng18 is offline   Reply With Quote
Old 12-07-2013, 02:44 PM   #3
I had issue with servo interference up front, when converting to the 4 Link.
During compression the servo's horn would hit the forward cross member.
It didn't help that I rotated the axle forward as well.
^ upper links were extended about 2mm.
I did not use a servo relocation kit...
and instead shaved some material off the plastic servo mounts.
This allowed the servo to shift slightly rearward.
Just enough that the servo's horn clears the forward cross member.
You could also shorten your upper links...
however... you drive shaft's pinion angle might suffer from that.
TacoCrawler is offline   Reply With Quote
Old 12-07-2013, 02:56 PM   #4
This Honcho I am building from spare parts so at the moment I am just trying to piece things together. I will see what I have stock parts wise.. Is this the Blue Monkey kit you are talking about?
DIY CMS and Panhard Kit, Blue Monkey RC
I also came across a thread with a link to Level 3 RC and an RC4WD servo front axle relocation kit. Anyone using those?
Thank I might give that a try too.
Old 12-08-2013, 04:03 AM   #5
I converted my honcho to 4 link using the factory front truss and really didn't have a fitment issue with it...Im not sure why you would have a problem unless maybe using something different from stock to begin with that may require mods to make it work correctly.
Youll find a lot of mods aren't just drop in and go..some require additional parts or mods to make them work/fit properly...Make sure you do your home work before buying just anything for the build.
6sharky9 is offline   Reply With Quote
Old 12-08-2013, 06:21 AM   #6
GCM makes a steering servo relocation bracket.
GCM Racing WebStore-2013 - SCX Servo Mount
rcwolf is offline   Reply With Quote
Old 01-06-2014, 04:53 AM   #7
Hmm I like the Loki of some of those anyone running any of the GCM stuff on their SCX10?
Sent From My Mobile Device Using Tapatalk Pro
Old 01-06-2014, 05:19 AM   #8
I know guys that do and they love them.
T I N Y is offline   Reply With Quote
Old 01-06-2014, 08:16 AM   #9
how does the GCM servo mount deal with the bump steer issue? or does it? edit: sorry I found the panhard set on GCM's website...
allanon1965 is offline   Reply With Quote
4 Link Set Up Help - Similar Threads
4 Link set help! Division 1.9 Scale Rigs 3 02-18-2011 04:54 AM
three link set up Nasty Newbie General 8 11-08-2005 11:46 AM
