12-12-2013, 09:45 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: Pierce County
| front upper link assistance...
I have a 2012 Jeep Wrangler scx10 RTR kit with a 3 link upper setup which has worn out. In looking at the extra parts which came with the kit, I have 4 extra links from parts tree number AX80043 item number 2. Can anyone confirm if that's the links needed for the front upper 4 link setup? Looks like I have everything else needed including the 4 link truss an the plastic joints to insert in the links. I am thinking a aluminum 4 link setup in my future, probably early next year. But I want to make a axle swap first. So this repair is just to allow me to run the rig during the winter. Thanks, John |
12-12-2013, 10:18 PM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: front upper link assistance...
Looks like that should work to make the 4 link front as long as you have the spare truss. Try it and see how it all fits. Servo might hit the front cross member if the links are too long up top. My Jeep came 4 linked front with custom made links. I had to make the uppers about 2mm longer to get the front pinion rotated up so the DS angle wasn't so steep!! Last edited by ZippoMan; 12-12-2013 at 10:21 PM. |
12-12-2013, 10:20 PM | #3 |
Rock Stacker Join Date: Mar 2013 Location: La Serena - Chile
johnfm3 look at this post for the links length My Honcho RTR and some mods I have a honcho and it's the same wb as the jeep. |
12-13-2013, 09:04 AM | #4 |
Thanks for the info on the length, but I am not in a position to do that at this time. If the parts I have are not the correct ones, then I will repair the 3 link with those parts I do have an run it longer. This summer I am planning a Wraith axle swap an Suspension Lift an want to build custom longer links. John |
12-13-2013, 09:39 AM | #5 |
So I called axial support to see if the parts tree AX80043 contained the front links. The result of this call was no good. At this time, with XMass around the corner an a family including 5 kids, I am not doing anything more than replacing whats there with the spare parts which came with the kit. I will deal with this after the new year when I can invest funds in my hobbies. Given the lengths provided, I may see if a local auto parts store can measure the length an let me know if the ones I have are the correct length. Keep ya posted. John |
12-13-2013, 10:03 AM | #6 | |
| Re: front upper link assistance... Quote:
12-13-2013, 10:06 AM | #7 |
| Re: front upper link assistance... I own 2 full size jeeps which I build most my own parts for, an being with in a 1/8 of an INCH (not metric) is close enough for the welder to correct... I think what a better suggestion would be to invest in a digital Micrometer. As I keep telling myself I should get one an never do. John |
12-13-2013, 10:56 AM | #8 | |
12-13-2013, 11:03 AM | #9 |
| Re: front upper link assistance... |
12-13-2013, 12:07 PM | #10 |
03-31-2014, 05:39 PM | #11 |
So I am resurrecting this old thread. So since this thread was started, I have come along way with my SCX an have purchased a wraith. I may be purchasing some 120mm HS Shocks which will give my rig quite the lift. An I am now on the hunt for good ways to stretch my wheel base. To anyone who has built a wroncho an used the wraith links an scx belly pan, do you find it stretches the wheel base pass the 12.3 inch (313mm)? I am trying to see what Axial may have provided me to work with for links with out going custom. If I go the custom route, the thought of going 3 link sounds appealing as well to steer clear of the drive line. I am not totally sure where this first real build of my suspension will go. I will keep every one posted. Thanks, John |
04-01-2014, 09:23 AM | #12 |
So I stopped by the local hobby store. After spending some time comparing different links, it appears the 313mm SCX has the longest links of all the axial products. So my only option is to go custom. John |
front upper link assistance... - Similar Threads | ||||
scx10 front upper link | jt4X4 | Newbie General | 2 | 08-30-2013 02:24 PM |
VP Front Upper Link Mount | Greatscott | Axial XR10 | 25 | 11-27-2011 08:40 PM |
