12-14-2013, 06:30 PM | #1 |
Rock Stacker Join Date: Dec 2013 Location: san diego
| VP zero Ackerman knuckles
The guy at VP told me the stock steering rods would work. Well, they don't. Which steering rods do I use for the zero ackerman knuckles? I have the scx10 g6 Thx Last edited by teeforb; 12-14-2013 at 06:52 PM. |
12-16-2013, 06:56 AM | #2 |
| Re: VP zero Ackerman knuckles
Anyone?
12-16-2013, 07:03 AM | #3 |
Newbie Join Date: Aug 2013 Location: Youngsville, NC
I dont got them on my rig but ive seen them around and im thinkin they use the titanium steering links from VP. Possibly for the curries
12-16-2013, 07:56 AM | #4 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
It doesn't say on the website for JUST the knuckles, but if you go to the link for the Stage 1 kit, here is what is quoted: "Will require new tie rod and drag link, due to this being a high steer zero ackerman knuckle." I had done a crap load of research on the forum before ordering and ordered the Currie Tie Rod and Drag link while i ordered the stage 1 kit. Currie/SCX Titanium tie rod / drag link But i'd call the guys up at VP though and talk to someone else and tell them what you were told. They should know what does and doesn't work. |
12-16-2013, 10:12 AM | #5 |
Thanks guys for the info. I'll check out the links
12-16-2013, 10:13 AM | #6 | |
What's the stage 1 kit? Do you have to order both? Quote:
12-16-2013, 10:16 AM | #7 |
the stage 1 kit includes the Vanquish Products 8 degree knuckles (Zero ackerman), chubs and lockouts all in one kit for a little cheaper than buying each separate. But the stage 1 kit does not include the Currie links, so yes, you'll need to order those separate. Something else that might not have been mentioned is you may need to use wider hexes as well (I had to use the 12mm hexes on the front axle) |
12-16-2013, 12:50 PM | #8 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
what are you doing for a servo and axles and stuff to go with the knuckles?
12-16-2013, 01:10 PM | #9 |
me or the OP?
12-16-2013, 01:29 PM | #10 |
| Re: VP zero Ackerman knuckles |
12-16-2013, 02:18 PM | #11 | |
| Re: VP zero Ackerman knuckles Quote:
I was recommended to get wider hex. I have them. I think they are the traxxas ones. I can't recall. but yes, they are wider. thanks for the heads up! | |
12-16-2013, 02:20 PM | #12 |
| Re: VP zero Ackerman knuckles is this question for me? If so, i'll be running a hitec 7955 (i think that's the number). I also go a 15A external BEC from turnigy. I am running a trackstar 120A esc and trackstar 17.5T on a 3S.
12-16-2013, 02:26 PM | #13 |
With the stock plastic hubs and zero knuckles, does the currie fit exactly or do you need hacking?
12-16-2013, 02:56 PM | #14 |
RCC Addict Join Date: Oct 2012 Location: Norcal
I used Blue Monkey rods: Titanium Steering Linkage for SCX10, Blue Monkey RC You have to pick the 8 degree ones. They come with everything you need. Last edited by Norton; 12-16-2013 at 03:01 PM. |
12-16-2013, 03:10 PM | #15 |
i talked to VP. i'm returning the zero ankerman and ordering the stage 1 kit with the currie axles. This way, everything will fit exactly!
VP zero Ackerman knuckles - Similar Threads | ||||
VP zero ackerman knuckles | helhedded | EnRoute Berg | 1 | 03-16-2010 06:25 PM |
help with ackerman knuckles | GEARSCIENCE | EnRoute Berg | 2 | 12-06-2009 03:45 PM |
