12-15-2013, 11:49 AM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: brockville
| getting my rtr rubicon 3s ready
I'll be placing an order for the rtr rubicon at tower hobbies tomorrow to take advantage of the great deal they have right now... What do i need to make it 3s ready? will the axial aluminum upgrade kit for 60 keep it from breaking? I know the esc is good enough but what about the servo? Thanks in advance guys can't wait to get it |
12-15-2013, 11:51 AM | #2 |
| Re: getting my rtr rubicon 3s ready
Would be ideal to keep the buying all in one place to get the 400 coupon :-)
12-15-2013, 12:38 PM | #3 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
You'll need a bec and steel tranny gears and outputs to start.
12-15-2013, 12:45 PM | #4 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
You will need links, a castle bec, a 13tooth 32pitch pinion with a 56tooth traxxas Jato spur.
12-15-2013, 01:25 PM | #5 |
Can these be had at tower? I'm checking now
12-15-2013, 02:12 PM | #6 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Get the 100 dollar titanium links..the aluminum ones just don't hold up..better to get the best now. you need 100 dollar axles you need a 150 dollar servo High steer aluminum knuckles 30 dollars expensive aluminum c hubs 30 dollars 50 dollar drive shafts about 100 dollars in trans upgrades lower gear..idler gear..the shaft..the stock case is plastic..so better get the aluminum case 60 dollars you need 75 dollar shocks you need 50 dollar shock hoops don't use the stock esc..its junk..you need a 350 dollar brushless system or its going to be underpowered. you need 125 dollar wheels you need to change your gears in the axles cuz they suck..50 dollars 3s is weak..go for a 6s for power Don't forget steel bumpers..those just make all the difference in performance. I almost forgot to mention the torque tubes..youll need those cuz the plastic ones break even with 2s power Currie axles would be better than stock too..the stock ones just cant take any kind of power..400 dollars youre gonna have a badazz truck man Last edited by 6sharky9; 12-15-2013 at 02:17 PM. |
12-15-2013, 02:15 PM | #7 |
I personally would just get a better servo, a ccbec, Axial link upgrade kit, and Axial chubs and knuckles. That should do you fine for awhile. Tell us about what you will be doing with it?
12-15-2013, 02:35 PM | #8 |
Ahh sharky if only i had your deep pockets :-P can i use the arrma pinion? Can't find an axial one in that configuration
12-15-2013, 02:37 PM | #9 |
I sent you a pm
12-15-2013, 02:37 PM | #10 |
Thanks for the input 666, I'll likely be trailing and light crawling with it..being a newbie i def like the power of the 3s to plow and bash once in awhile lol
12-15-2013, 02:53 PM | #11 |
I def caught the sarcasm there sharky LOL ,thanks for that other write up too btw i find it real informative for a guy on a realistic budget!
12-15-2013, 03:10 PM | #12 |
Will the cc 10 amp 6s bec work for this?
12-15-2013, 03:13 PM | #13 |
yes
12-15-2013, 03:14 PM | #14 |
unless they make them for specific batteries only which im not aware of.
12-15-2013, 03:33 PM | #15 |
Right on thanks,i see cc makes the pinion as well,i assume it will work? Its twice the price of the arrma tho
12-15-2013, 03:37 PM | #16 |
What hitec servo would you recommend? Standard metal gear for 20?
12-15-2013, 05:09 PM | #17 |
Quarry Creeper Join Date: Sep 2013 Location: New Zealand
I wouldn't go HiTec. I've had an awful run with them. Broke and $60 servo in 8 days. Bought another and it was a goner in a month. I'd buy Savox |
12-15-2013, 06:23 PM | #18 |
Anything at tower you would recommend? Was looking at the futaba but its not recommended for lipos?
12-15-2013, 06:46 PM | #19 |
Newbie Join Date: Mar 2013 Location: Dallas
Don't forget the RTR esc is only 2s compatible.
12-15-2013, 07:11 PM | #20 |
I def overlooked that..
getting my rtr rubicon 3s ready - Similar Threads | ||||
Is the Axial Rubicon Brushless Ready? | Beowulf | Newbie General | 4 | 08-24-2013 05:21 AM |
My Jeep Rubicon RTR Vids | Jafo99 | Scale Videos! | 0 | 04-28-2013 12:34 PM |
just got my rubicon unlimited rtr just a few ?'s | gcl76 | Axial SCX-10 | 3 | 02-22-2013 01:35 PM |
Dune Ready Jeep Rubicon | CRUZ CONTROL | 1.9 Scale Rigs | 104 | 02-01-2008 05:45 PM |
