12-21-2013, 10:58 AM | #1 |
Rock Stacker Join Date: Dec 2013 Location: san diego
| scx10 servo not fitting
what am i doing wrong. the servo horn is hitting the currie rod and no clearance from the chassis when suspension is pushed. |
12-21-2013, 11:17 AM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: scx10 servo not fitting
Maybe flip the servo horn 180* from where it is now.
12-21-2013, 03:21 PM | #3 |
Quarry Creeper Join Date: May 2010 Location: scotland
put the long rod underneath the knuckles instead of ontop or get a shorter servo arm just noticed you have the rod screwed into the closet hole have you tried moving it to the furthest away holes on the knuckle |
12-21-2013, 06:19 PM | #4 |
Ok thanks! I'll try that
12-21-2013, 10:12 PM | #5 |
I shaved the the forward side of servo's plastic mounts down some. Maybe about half the thickness (front to back) This allowed the servo to shift rearward just enough. I also used shorter button head screws to mount the servo. If the horizontal screws are too long... they will bottom out on the two vertical screws holding the servo tray and won't be able to thread in far enough to secure the servo to the mounting blocks. You could also shift the mounting plate rearward slightly.. But would entail drilling new holes and counter sinking those. What wheel base do you have currently ? Are the upper link rods longer then was original ? Commonly longer (then original) upper link rods will rotate the axle housing forward some... and push the servo forward causing interference with the cross member. I'm purdy sure that when using the original link rods... this interference does not occur. I've seen some completely remove their forward cross member... Though I think that will weaken the frame somewhat. If removing that forward cross member.... I would advise to at least use a cross tube tied into the frame rails to help box the frame at the front. I realize there is an end cap that ties the two frame horns together... But that is not enough boxing to the frame to maintain its strength. Well... IMO anyways edit: I'm not familiar with that KO servo nor it's size dimensions... But it looks like the front facia protrudes forward more then some others. This difference might make the servo seem to sit farther forward. you might want to look into that farther. Is this KO servo a standard sized servo ? Last edited by TacoCrawler; 12-21-2013 at 10:29 PM. |
12-22-2013, 07:55 AM | #6 |
In the band for now. Join Date: Sep 2012 Location: roselle
move the tie rod to the forward holes on the nuckle
12-22-2013, 08:47 AM | #7 |
| Re: scx10 servo not fitting |
12-22-2013, 09:31 AM | #8 |
Quarry Creeper Join Date: Aug 2007 Location: El Dorado Hills Ca
The stock servo horn is thick. Issue with mone on the G6 build was the top of the horn was hitting the chassis not allowing any up and down movement in the suspension. As mentioned above, I shaved mine down and it works fine. I then went and got a metal horn and its works well also. Much thinner and more dependable then the plastic. No worries of it stripping at the spline. Last edited by FastEddy; 12-22-2013 at 09:33 AM. |
12-22-2013, 10:16 AM | #9 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
I was having issues with my set up too. I like the Axial clamping servo horns but they are very thick. I think with my set up the guy who built the SCX-10 Jeep used too long of custom lower suspension links and funky custom uppers. My servo horn would have hit the custom tie rod so I put round spacers and mounted it under the steering knuckles using the most forward holes. I noticed my drag link was not in a straight line to the steering knuckle when mounted on top of the forward hole so I mounted it in the back hole. Sure it may look different but it works. I was losing my mind trying to figure out why I had so many issues!! I had the issues of the frame cross member hitting the servo horn. I solved that by making my front upper links about 1 or 2mm longer...tricky but it worked. I was so used to my Wraiths where there is tons of room to mount and play around with servo horn combos and mounting positions. I never had an SCX-10 based RC before so this is a new beast to challenge the mind. LOL If I was to spend any more money to fix this right for my OCD, I would buy all new suspension links to correct the overall wheel base. I can't just cut the lower links because they are 1/4" SS custom bent. Oh well the set up I have is working but may not look like everyone else's....lol Last edited by ZippoMan; 12-22-2013 at 10:21 AM. |
12-22-2013, 10:33 AM | #10 |
Oh and I second the flipping of your servo! Look at the instructions. The horn works best when mounted like in the instructions. |
12-22-2013, 02:25 PM | #11 | |
| Re: scx10 servo not fitting Quote:
because adding length to the upper link rods is usually what shifts the servo forward. My Axial alloy clamping servo horn cleared fine until I added 2 mm spacers to the upper link rods. After adding those 2mm spacers to the upper link rods... is what required me to move the servo rearward slightly. After adding 8* Axial alloy C-hubs/knuckles... I'm wanting to rotate the axle forward a little more by adding maybe a total of 4 mm to those upper link spacers. But in doing that... will need to move my servo mount even farther rearward to clear the forward cross member. sooo... I haven't attempted that as of yet. | |
12-22-2013, 02:28 PM | #12 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
"After adding 8* Axial alloy C-hubs/knuckles... I'm wanting to rotate the axle forward a little more by adding maybe a total of 4 mm to those upper link spacers. But in doing that... will need to move my servo mount even farther rearward to clear the forward cross member." you can move the cross member forward like I did Last edited by 6sharky9; 12-22-2013 at 02:31 PM. | |
12-22-2013, 02:54 PM | #13 |
| Re: scx10 servo not fitting You usually post one anyways LoL true... or just omit that. and add a single tube to span... The boxing can occur between that spanned tubing... and a solid forward mount at the frame horns. As long as the forward side of the frame is boxed. It should offer the strength needed up front. Without boxing on the forward end of the frame... a hard hit could fold the frame rails. Yeah maybe no real issue at slow speeds... But take a 20ft tumble down a rock pile... and ya may find out the hard way. |
12-22-2013, 03:47 PM | #14 |
Okay so maybe I was wrong about why I changed the length of my uppers...oops. I did it so my drive shaft angle wasn't as sharp. Yeah I had a brain fart again.....lol. I was able to move my cross slightly ahead but I can't eliminate it due to how my battery is located up front now. Overall I am fine with my set up now. It is my gf's Jeep so it won't get much use in hardcore situations anyway. It may become an expensive shelf queen I hope not. :P I still will say flip that servo over!! Last edited by ZippoMan; 12-22-2013 at 03:58 PM. |
12-22-2013, 05:57 PM | #15 |
My opinions of what should be done... * random thought... so no real order here. Lol Besides relocating the servo rearward some... I'd probably pick another servo to use. The forward facia profile on that KO servo looks to protrude more then many others do. ( measured from the facia to mounting surface ear(s) ) I had a similar issue when moving from the oem Axial servo to a futaba S3305. (Axial warranty replacement) The S3305 had a taller facia profile then their oem servos and required I move the servo farther rearward to alleviate clearance issues at the forward cross member. Move the primary steering link rod to the forward holes at the steering knuckle arms. Mounting them at the inner holes reduces steering throw as well as causing more possible interference at the link rod and servo horn. I can't say whether mounting the primary link rod under the knuckles will offer any advantage. But moving those link mounts to the outer holes should help the link rod to clear the servo's horn better. It does not matter much which position the servo sits (left or right) with regards to drag link interference/bind. But generally a shorter drag link length can bind more then a longer drag link length might. Spacing the drag link ends off the servo horn mounting might be helpful in reducing bind as the servo arm moves (left/right). * But too much... and the bind there could be worse. ^ This could be dependent of how far the servo is pushed rearward. I use the shorter drag link currently (horn/DL on drivers side) But I intend to run the drag link to the passenger side... to see if that movement offers less bind at full steer (left/right). One might even think to mount the drag link end to the inner surface of the servo horn's arm. Thing is... the farther the servo is mounted rearward... the less likely the drag link could be mounted on the backside of the servo's horn. I believe that Axial installed the shock spacers on their shocks because when compressed fully, the drag link would hit the frame. I use 100mm CO's so they bottom out before the drag link hits the frame rail. So yeah... my suspension likely doesn't compress as much as it might have when using the oem CO's without the spacers on the shafts. and yeah, the suspension ride height would end up being taller (lifted slightly)... But I have about 3/4" of static squat with my CO's (50/50 travel)... so tho' my 100mm CO's do droop lower then originals... the static ride height is actually less then oem. So in closing and making it a short list.. the most critical things are... Relocating the primary link rod to the outer holes of the knuckle's arms and moving the servo rearward some on it's mounts. ^ that order * test susp. function after each adjustment is made. (Servo shift may not be required !?) Last edited by TacoCrawler; 12-22-2013 at 07:01 PM. |
12-22-2013, 06:09 PM | #16 |
I still say flip the horn
12-22-2013, 06:46 PM | #17 |
12-22-2013, 07:09 PM | #18 |
Quarry Creeper Join Date: Apr 2013 Location: perkasie
It looks like the steering knuckles are on the wrong sides....if you switched them side to side the mounting point would be way lower and nothing would be hitting Sent from my PI39100 using Tapatalk |
12-22-2013, 07:09 PM | #19 |
The knuckles are on the wrong sides.... Sent from my PI39100 using Tapatalk |
12-22-2013, 07:31 PM | #20 |
| Re: scx10 servo not fitting Flip the horn 180*, attach the tie rod to the horn, add a 3 or 4mm spacer between where the tie rod attaches to the drag link, go in the Tx and reverse the steering. Done.
scx10 servo not fitting - Similar Threads | ||||
Fitting a yota interior with stock scx10 internals | Northwestrc | Paint and Body | 1 | 04-27-2013 12:13 PM |
Fitting XR Wheels | ElectroTech | Axial Wraith | 3 | 10-18-2012 12:25 PM |
Fitting 2.2s on a Dingo | Tbone | Axial SCX-10 | 1 | 09-16-2012 12:26 PM |
Fitting the Cherokee body on the 12.3" scx10 | Dustytrac | Newbie General | 3 | 03-31-2011 08:50 AM |
fitting a brake servo | klampykixx | Newbie General | 10 | 06-26-2010 03:59 AM |
