12-24-2013, 07:35 AM | #1 |
Rock Stacker Join Date: Dec 2013 Location: san diego
| Scx10 tires
Should I keep the stock tires or should I go after market? Looking on amain, top two sellers are the proline super swampers sx xl and the HB rovers. The rovers look more attracting due to price. You guys thoughts? Thx |
12-24-2013, 08:04 AM | #2 |
Pebble Pounder Join Date: Dec 2013 Location: MARIETTA
| Re: Scx10 tires
Tires are personal choice thing. personally I like the more scale (realistic) looking tires. Just because a tire is cheap does not mean that it will perform well. The Super Swamper is a great 1.9 tire and is one of my personal favorites. So my advice is to spend some extra money and get a good tire. You may also want to spend some time in the wheel and tire section as you probably find tons of usefull information there! |
12-24-2013, 08:10 AM | #3 |
| Re: Scx10 tires
Besides looks, what are the difference in wheels? I heard a few good reviews once HB tires. Wanted to get a comparison. Last edited by teeforb; 12-24-2013 at 08:13 AM. |
12-24-2013, 08:27 AM | #4 |
| Re: Scx10 tires
The rovers are going to be more of a crawler specific tread. They will most likely perform well in rocks. I have never run the rovers so can not personally attest to their performance. I have used the swampers and can say they perform exceptional in rocks and dirt. I have crawled some pretty crazy lines with them. so comparison wise i would say they should be pretty close to one another in the rocks.
12-24-2013, 08:33 AM | #5 |
Rock Stacker Join Date: Jan 2012 Location: Winston-Salem
| Re: Scx10 tires
I love the look of the MTZ's are had them on one of my 1:1 Jeeps. I'll probably get them once I want/need new tires Mickey Thompson 1.9 Baja MTZ Scale Tires |
12-24-2013, 08:47 AM | #6 |
Quarry Creeper Join Date: Sep 2012 Location: Emmaus, Pa
| Re: Scx10 tires
Just from reading on here, most popular are pitbull rock beasts. Them and what rubicon said, baja claws, I have to say though I do see the rock beasts recommendedbfor performance over any other scale tire. And trust me I read alot on here. You can even find pics of wheel/tire covered boobs if you look hard enough |
12-24-2013, 09:17 AM | #7 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Scx10 tires
Pitbulls definitely get good reviews..Ill be trying a set myself soon. You said your stock tires...So you have a rubicon or a honcho?. The Honcho stock tires (Ripsaws) ive personally found to be very good tires..Ive tried the trepadors and proline flat irons and always seem to go back to the ripsaws. What terrain you most frequent will help determine whats best for your particular application. Don't forget foams as that is just as important as tires themselves...The wrong foams in a good tires means a bad combo and doesn't work well. I cant recommend foams but Look on here in the vendors sections and look for Crawler Innovations...He will get you going in the right direction. Make sure you know your vehicles weight and some other questions he may ask you about your truck to select a good foam. As far as wheels your stock wheels will work but you can benefit from a basic set of beadlocks...Youll get a lot easier tire changes and in most cases the bead locks can help support side loads on your tire..Giving better bite and maybe that little difference in rolling over or not on a side hill. A basic Axial 8 hole beadlock set is better than the stock wheels but its not a must have. Hope this helps. Last edited by 6sharky9; 12-24-2013 at 09:21 AM. |
12-24-2013, 09:48 AM | #8 |
| Re: Scx10 tires
I have the g6 Are the pitbull rock beasts a larger profile than stock g6 tires? Where can I find them cheapest. Last edited by teeforb; 12-24-2013 at 09:52 AM. |
12-24-2013, 09:51 AM | #9 | |
Quarry Creeper Join Date: May 2010 Location: scotland
| Re: Scx10 tires Quote:
12-24-2013, 09:57 AM | #10 |
| Re: Scx10 tires
Which foams for after marker tires? Are the stock wheels ok?
12-24-2013, 09:59 AM | #11 | |
Crawler Innovations has pitbulls with standard foams for just under 60 dollars...They are just standard foams but should be better than the stock foams I would imagine..The height is within a minimal difference height wise if any...they fall somewhere between the ripsaws and the trepadors I think..so they are a good fit height wise.. | |
12-24-2013, 10:02 AM | #12 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Scx10 tires
I bought a Jeep JK from a fellow RCCer and he put new Rok Lox 1.9 Comp Tires. They look sweet with the Gear Head rims!! http://www.rpphobby.com/product_p/gea19tkezd.htm |
12-24-2013, 10:05 AM | #13 |
| Re: Scx10 tires |
12-24-2013, 10:11 AM | #14 |
| Re: Scx10 tires
Are the pitbulls multi-purpose?
12-24-2013, 10:14 AM | #15 |
Rock Stacker Join Date: Dec 2013 Location: San Jose
Better yet, if you do get the Rock Beasts from Crawler Innovations, get the combo with the Deuces Wild foams. You won't regret it. Sent from my RM-860_nam_usa_100 using Tapatalk |
12-24-2013, 10:18 AM | #16 |
| Re: Scx10 tires Im thinking they are...Some tires are rock specific...Some are mud specific SOme may be double duty etc....Pitbulls are based on real off road tires for a number of tasks..these are also but these seems to get great reviews in most general off road purposes. |
12-24-2013, 10:19 AM | #17 | |
These are the exact pair right? Will these work as multi-purpose as well? http://www.crawlerinnovations.com/in...mart&Itemid=72 Last edited by teeforb; 12-24-2013 at 10:22 AM. | |
12-24-2013, 10:20 AM | #18 | |
In other words tell them what you have..if they recommend that tire foam set up then go for it. | |
12-24-2013, 11:19 AM | #19 |
| Re: Scx10 tires
I don't understand the beadlock wheels. Do they not sell them complete? Looking on VP, it looks like u need to buy them separate. Do they have plastic beadlocks? Last edited by teeforb; 12-24-2013 at 11:25 AM. |
12-24-2013, 11:31 AM | #20 |
| Re: Scx10 tires
Since its a new truck you have you probably want new but you can find some decent used VP wheels in the for sale section if that's what your after.
Scx10 tires - Similar Threads | ||||
best way to get these tires on a scx10 | arp1500 | Axial SCX-10 | 10 | 04-15-2012 12:15 AM |
1.9 Snow Tires for SCX10 | baconCHDDRchips | Tires and Wheels | 31 | 10-12-2011 08:39 PM |
