12-27-2013, 02:56 AM | #1 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| aluminum axle housing choices?
Ok I'm looking into some aluminium axle housing. I'm only coming up with 3 current choices ,VP, Curries , RC4WD. Are these three only options that are worth buying? I've seen the Integy makes one as well but I've not seen or been able to find a reviews of them. I'm just having a hard time forking out the cash for the VP/Currie set up at @ $400 total and that's not complete,that's just the housing using my internals. The VP housing would not be bad but the integy complete axle can be had for @ $90 a side, the rc4wd housing looks ok but it's outta stock. Anyhow I'm on the search for aluminum axle housing.
12-27-2013, 03:20 AM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: aluminum axle housing choices?
I'm interested to know as well. I've tried to get more info on the Integy axles, but to no avail. I want to be able to change the gears in them.
12-27-2013, 04:03 AM | #3 |
The integy set up looks nice and priced right. I just know their track record is not good in the area of tolerances and material quality.
12-27-2013, 04:46 AM | #4 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
I have the integy axles on my dingo. Everything went together well all parts swap over from stock
12-27-2013, 05:01 AM | #5 |
How is the quality of the aluminum? T6?
12-27-2013, 05:05 AM | #6 |
| Re: aluminum axle housing choices? |
12-27-2013, 05:14 AM | #7 |
Yes do tell. The fact that axles and gears can be swapped out...I'm almost ready to place an order.
12-27-2013, 08:55 AM | #8 |
RCC Addict Join Date: Feb 2012 Location: Ca.
VP also does theseAxial scx10 ax10 Aluminum Axle Housing |
12-27-2013, 09:41 AM | #9 | |
| Re: aluminum axle housing choices? Quote:
12-27-2013, 10:19 AM | #10 |
Vanquish is abit pricey for me.
12-27-2013, 10:25 AM | #11 |
| Re: aluminum axle housing choices? Agreed. I wish blinkme would come back and answer the question of "how long and how hard" however. Integy and RC4WD metal seems too soft to me. I had plenty of problems with TF2 housings. Can't speak to Integy housings however.
12-27-2013, 10:29 AM | #12 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
12-27-2013, 10:30 AM | #13 |
| Re: aluminum axle housing choices? Yep, just thought I'd show another option is all. I used VP housings on my Wraith and beat the hell out of them with no problems.
12-27-2013, 10:34 AM | #14 |
Is it just looks your after?
12-27-2013, 10:55 AM | #15 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
Alum axles housings hang up a lot more imo Sent from my Optimus G Pro using Tapatalk |
12-27-2013, 11:02 AM | #16 |
12-27-2013, 11:06 AM | #17 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
12-27-2013, 11:37 AM | #18 |
I already have beef tubes. I need more low cog
12-27-2013, 11:44 AM | #19 |
GCM Metalheads. nothing left to say.
12-27-2013, 11:48 AM | #20 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Or keep the stock SCX10 axle housings and then install: -Beef Tubes -Vanquish Wraith/XR10 Chubs and Knuckles -RCBros or BlueMonkeyRC knuckle weights -Locked Up RC, Vanquish, Hot Racing or Die-Laughing lockers There's all of your low center of gravity and a bulletproof axle. I said it before and I'll say it again: Vanquish upgrades become the cheapest upgrade you've done to your rig later down the road. Yes you pay for it upfront but it's better than having to replace the "upgraded" parts multiple times. Eventually paying more on that same "upgraded" part than what you could have bought a Vanquish part for and be spending your money on other upgrades. Last edited by Lentsnh2012; 12-27-2013 at 11:51 AM. |
aluminum axle housing choices? - Similar Threads | ||||
VP aluminum axle housing | Quartermaster | Axial Wraith | 14 | 02-17-2012 09:33 AM |
Aluminum axle housing | s14slide | Venom Creeper | 6 | 01-07-2010 01:08 PM |
aluminum axle housing 4 txt | allupinya51 | Tamiya Txt-1 and Juggernaut | 2 | 12-16-2005 02:39 PM |
