12-29-2013, 01:53 PM | #1 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| G6 servo mount 4 link binding To everyone that has a G6 kit. You may want to take a 2nd look at the space between your servo mount plate and your upper link bars. Mine a making contact with the servo plate. To fix this I used the 2 pacers that came in the pack with the kit I just put them under the servo plate to get the extra space needed. I found this on my kit and i hope it helps others. Last edited by THX_138; 05-12-2014 at 10:22 PM. |
12-29-2013, 05:00 PM | #2 |
Pebble Pounder Join Date: Jan 2013 Location: Hesperia
| Re: G6 servo mount 4 link binding
I noticed during the build that the servo mount and the upper links were really close, but I lowered the suspension as low as it could and it seems to just clear. I could see it rubbing having more suspension lift. Good idea with the spacers. |
12-29-2013, 07:32 PM | #3 |
Rock Stacker Join Date: Dec 2011 Location: Gosport
I also built a G6 kit and the servo also hits the frame brace that the battery tray screws to. I removed the brace which gave it more flex and i havnt had any problems with the battery tray.
12-29-2013, 08:57 PM | #4 | |
| Re: G6 servo mount 4 link binding Quote:
12-31-2013, 04:45 PM | #5 |
Newbie Join Date: Sep 2011 Location: metro
I ended up grinding down the cross brace that got in the way of the servo, just enough to still have the strength for the battery mount up front. I think it will be fine that way. Seems stiff enough. I did not have the problem of the struts hitting the servo plate. Just paint and body stuff left. The rest of it went pretty good.
05-14-2014, 06:46 PM | #6 |
| Re: G6 servo mount 4 link binding Tihis is what i did to stop the link bars from rubbing the servo plate. I cut some of the servo plate of as the rear mount hole is not used. Its about 1/2" you need to cut off Last edited by greengoblin; 05-14-2014 at 07:20 PM. |
05-19-2014, 12:25 AM | #7 |
Rock Stacker Join Date: Aug 2013 Location: Sacramento
Is anyone having this problem with their G6 kit? Where my upper steering link attaches to the provided axial servo horn runs into the cross brace of the chassis and prevents a little more suspension travel when you compress both front shocks at the same time. Is this common or did I out something together wrong? Here is a pic of the contact... |
05-19-2014, 06:48 AM | #8 |
Rock Crawler Join Date: Oct 2012 Location: Casper
It will probably never reach that point under it's own weight. You can notch the crossmember a little if it bugs you though.
05-19-2014, 09:12 AM | #9 | |
Thanks for the reply. That's a great point I didn't think about that. I was just curious if this was typical on the G6 kit build. I do get full range of motion during full articulation so that is all that matters. | |
05-24-2014, 05:39 PM | #10 |
| Re: G6 servo mount 4 link binding That happens in all axials with the 98mm front links. Most people dont run that front brace but if you have the battery in front You have to have it. I just notched mine so it dont hit. Last edited by greengoblin; 01-18-2015 at 09:19 AM. |
05-24-2014, 05:43 PM | #11 | |
Thanks for the information. I appreciate it. Eventually I will relocate the battery to the middle but for now it stays. | |
05-24-2014, 05:58 PM | #12 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
| Re: G6 servo mount 4 link binding |
05-24-2014, 06:09 PM | #13 |
Yeah I finally just notched enough I the cross member for the screw head to pass by. I will eventually make my own mount and move the battery to where you have it in the last photo
05-26-2014, 11:01 PM | #14 |
Newbie Join Date: Dec 2013 Location: Fresno, CA
I just removed the cross member all together. I made a new battery tray out of lexan and now have the battery lay across the chassis behind the shock hoops.
G6 servo mount 4 link binding - Similar Threads | ||||
Axle Shock/Link Mount Binding | RickM | EnRoute Berg | 10 | 02-18-2011 06:37 AM |
BWD Modular Servo Mount/Battery Tray/Adjustable Upper Link Mount | billet works | HPI Wheely King | 18 | 07-05-2010 10:52 AM |
which servo mount 4 link for AX!0. | Tipilot | Newbie General | 5 | 11-03-2007 09:55 AM |
