12-29-2013, 06:29 PM | #1 |
Rock Stacker Join Date: Dec 2013 Location: canada
| axial rubicon unlimted 2012 mod
What need to be upgraded ,I upgraded the steering kit allready . Thanks |
12-29-2013, 06:43 PM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
| Re: axial rubicon unlimted 2012 mod
absolutely nothing just drive the crap out of it until something breaks....which is going to be a long time unless you plan on dropping your truck from a 20 ft cliff most will say replace the servo but its quite capable and you can waterproof it yourself if you plan on playing in the water. Just replace the bearing as Axial outlined here -> Axial Racing - Axial’s AS-3 Servo Upgrade only other thing I would do is switch to 4 link front and rear |
12-29-2013, 06:51 PM | #3 |
I know about the bearing ,how about the front hubs ? Also the 4 link (it's plastic right now ) |
12-29-2013, 06:59 PM | #4 |
I've upgraded to aluminum c-hub's, knuckles, and rear lockouts on my G6 its not really needed or necessary. The plastic is fine for the 4 link. RC4WD just came out with an aluminum 4-link kit for the Rubicon, they states its for the rear but you can use it for the front but you may have to modify it...plus the price you can't beat it Rock Krawler 4 Link package for Axial Jeep Rubicon |
12-29-2013, 07:03 PM | #5 |
Rock Stacker Join Date: Dec 2011 Location: Gosport
If you do plan on playing in water i would suggest marine greaseing your axles. I have found that stock kits tend to have bearing noises even after one run through water if nothing is done.
12-29-2013, 07:14 PM | #6 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
16T motor pinion gear Aluminum steering link set Aluminum front and rear suspension link sets Convert the front to 4 link..(You should have the part to do this in the spare parts bag.) Servo bearing mod Use a 2s lipo battery Move the battery to the front of the chassis like the honcho For anything else just drive it and see how it holds up for you..if you break something easy then get an upgrade. |
12-29-2013, 08:15 PM | #7 | |
| Re: axial rubicon unlimted 2012 mod Quote:
12-31-2013, 03:57 PM | #8 |
| Re: axial rubicon unlimted 2012 mod |
axial rubicon unlimted 2012 mod - Similar Threads | ||||
rubicon 2012 unlimted 4 link | airride | Axial SCX-10 | 1 | 12-28-2013 07:50 PM |
Axial Rubicon mod day... | tomvaillencourt | Axial SCX-10 | 20 | 01-17-2013 10:18 PM |
KC's 2012 axial JK rubicon | kaneohecrawler | Axial SCX-10 | 8 | 01-12-2013 01:52 PM |
