12-29-2013, 10:58 PM | #1 |
Newbie Join Date: Nov 2013 Location: Austin
| DAF's first crawler
I'm starting this thread for the scx10 Rubicon i got for Christmas, i know its been a few days but I've been running this thing into the ground. I drive it around Christmas day with my little brother and just got the feel of it.
12-29-2013, 11:54 PM | #2 |
| Re: DAF's first crawler |
12-29-2013, 11:54 PM | #3 |
12-29-2013, 11:55 PM | #4 |
I get a solid 4 and a half inches of flex with the rubber bump stop removed.
12-29-2013, 11:56 PM | #5 |
12-30-2013, 12:05 AM | #6 |
esc is wrapped in a balloon and zip tied to the box and receiver is in a balloon and put in the box as well, i used some dielectric grease for the servo and you can find out how to do that on axial.com. It crawls really well with all the weight in the front.
12-30-2013, 12:30 AM | #7 |
12-30-2013, 12:32 AM | #8 |
made my own links. used some traxxas rod ends 3/8 threaded rod and 9/32 aluminum rod to sleeve them, id say they turned out really good for my first time, and man i have abused these in the last few days, they are holding up great!!
12-30-2013, 12:34 AM | #9 |
12-30-2013, 12:35 AM | #10 |
12-30-2013, 12:37 AM | #11 |
so now im stuck between try and get a new piece of should i just get a set of new shocks, all 4 of these stock ones leak oil pretty bad. I'm sort of on a money pinch but i do have a little extra, im not going to go with the pro line just cause i cant spend 50+ on toy shocks, id rather put that in my real truck. i have seen people using the traxxas big bore shocks and would love some input on those or any others you guys have used!
01-02-2014, 11:40 PM | #12 |
Newbie Join Date: Jan 2013 Location: Home
Looks good. As far as the leaky shocks go, you could try putting better o-rings in them. If you do want to get new shocks RC4WD has quite a few, but you are still looking at about $50-$100.
01-03-2014, 09:12 AM | #13 | |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: DAF's first crawler Quote:
01-03-2014, 09:36 AM | #14 |
Newbie Join Date: Dec 2013 Location: Denver
If you wanted to keep the shocks you could get some new spring cups that wont fall off. I use these......made by JeepinDoug. They are around $13.00 for four. Last edited by GasolineDream; 01-03-2014 at 09:43 AM. |
01-13-2014, 01:22 AM | #15 |
thanks for the comments and checking out my build! should have some more pics up soon, just been super busy with work and all. I did just ordre a pair or Gmade Junfac shocks 93mm with the aeration screw, about 26 and some change shipped to the door from rpp.com
DAF's first crawler - Similar Threads | ||||
Losi Micro Crawler Crawler-X SMC Plus Chassis Plus A Ton Of Stuff See Video | stomper4x4.com | Losi Micro-Rock Crawler | 5 | 05-14-2012 01:31 AM |
Difference in AX10, Night Crawler, and Comp Crawler final gear ratios? | shelljeep | Newbie General | 11 | 02-05-2010 12:48 AM |
TXT Crawler.... Stone Cold Crawler... Full Tube Scale build | RockSpyder | Tamiya Txt-1 and Juggernaut | 6 | 12-14-2004 09:40 AM |
