12-30-2013, 06:58 AM | #1 |
Newbie Join Date: Sep 2011 Location: metro
| New G6 Build - Bevel Gear bind?
So I finally dropped enough money to get a new G6 kit and stuck right off the bat. First of all I'm not new to RC at all. But this is my first crawler build. The axles are really binding. I pushed the pinion axle all the way down as the instructions say. But it does feel like it is still hitching on the bevel a little bit. I've read a few places that you need to get it perfect and others where you just need to run it and it will wear in. It's not terrible, but it's not smooth. Anyone else get this issue? Advice? |
12-30-2013, 07:09 AM | #2 |
Rock Stacker Join Date: Oct 2013 Location: Nampa
| Re: New G6 Build - Bevel Gear bind?
Chuck the input shaft into a drill and run it until it's smooth. The gears are cast and they have to wear into each other.
12-30-2013, 05:22 PM | #3 |
Ok, will do. Seems like they were a bit rough. Glad to know that it's not just me. I did keep going on the build and the rest is going pretty well.
12-30-2013, 05:28 PM | #4 |
Quarry Creeper Join Date: Nov 2013 Location: Erie
One of mine were as smooth as butter and the other had one little rough spot in it. I must of took the axle apart 4 or 5 times. Checked the gears and regreased. Then read on here somewhere about the drill trick. Now runs smooth like the other axle.
12-30-2013, 05:32 PM | #5 |
Rock Crawler Join Date: Mar 2012 Location: bel air
you check for flash left between the teeth? the small bits tend to blend in with that color grey
12-30-2013, 05:41 PM | #6 |
Newbie Join Date: Mar 2012 Location: Zelienople
I work at a LHS and had a cutomer was having the problem your having I pulled his apart and found nothing when I put it back together it was fine, He then retightend it and it got raspy feeling ? Your bolts are not over tightened are they ? He had his diff some what miss shaped. Causing gears to bind .
12-30-2013, 08:04 PM | #7 | |
Rock Crawler Join Date: Aug 2010 Location: Esko
Sent from my SAMSUNG-SM-N900A using Tapatalk Last edited by Tmaxxed; 12-30-2013 at 08:08 PM. | |
12-30-2013, 08:05 PM | #8 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk | |
12-30-2013, 08:10 PM | #9 |
Rock Stacker Join Date: Dec 2011 Location: Gosport
Mine did the same thing. I played around with it until there was just a little noise, went ahead and ran it and its been fine, no problems or noises.
New G6 Build - Bevel Gear bind? - Similar Threads | ||||
Bevel gear? | sixhundred71 | Axial Wraith | 5 | 05-10-2012 08:27 PM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
worm gear vs bevel gear? | fennex | Newbie General | 0 | 11-05-2010 06:57 AM |
bevel gear, ring gear mesh | rocksteadily | Tamiya TLT Crawlers | 5 | 05-09-2009 12:04 AM |
