12-31-2013, 02:45 PM | #1 |
Rock Stacker Join Date: Dec 2013 Location: san diego
| Junfac shafts for the scx10
I just installed the junfac shafts on the scx10. In the front, the male and females shafts are barely inserted and are very close to popping off. Anyone else have this problem? I have the scx10 g6
12-31-2013, 02:54 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Junfac shafts for the scx10
Junfac makes 4 or 5 different lengths of driveshafts. Just get the next size up and you'll be good to go. You can buy them in pairs or single from the Junfac website.
12-31-2013, 03:02 PM | #3 |
| Re: Junfac shafts for the scx10 I ordered on eBay and they were labeled as scx10 :( i messages the eBay store I purchased it from.
01-01-2014, 08:47 AM | #4 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
I had the same problem. I have a pair that are made for the wraith on the way. I believe the set they sent me were for the shorter wheelbase instead of the longer.
01-01-2014, 10:55 AM | #5 |
| Re: Junfac shafts for the scx10 isn't the g6 the standard 12" wheelbase? regardless, if it says scx10, it should fit regardless of wheel base. If no, advertisement needs to state which wheelbase.
01-01-2014, 12:09 PM | #6 | |
| Re: Junfac shafts for the scx10 Quote:
The Junfac drive shafts labled as "Hardened Universal Shaft for Axial Honcho #J90025" fits the 12/12.3 wheel base and is the same length as the Wraith shafts. Both shafts are 107mm to 142mm. | |
01-03-2014, 09:25 AM | #7 | |
01-03-2014, 09:35 AM | #8 |
Quarry Creeper Join Date: May 2012 Location: Biloxi
Measure twice, buy once. I ordered one rear shaft that I thought would and it ended up being short so I ordered a longer one and now have front and rear. The whole measuring with the travel and all confused me.
01-03-2014, 10:13 AM | #9 |
| Re: Junfac shafts for the scx10 The eBay add just says junfac scx10. It had no measurements. If it say scx10, one wouldn't think u need to measure.
01-03-2014, 11:08 AM | #10 | |
For example, RPP Hobby lists the shaft travel for both shafts for the "SCX10" shafts. They also have this warning: "These only fit the standard SCX10 They are not long enough for the Honcho version." A good vendor may cost slightly more than eBay but they make up for it in customer service. Doing the research is knowing the specs on the parts you are going to replace, or by doing measurements:
Also knowing the history of your rig and that there are multiple wheelbases possible should put you on alert for any part that is wheel base dependent. A lot of manufacturers and vendors still consider the 11.3 inch wheel base of the AX9007 as the standard wheelbase for the SCX10 and they may not have updated product information for the new SCX10 models such as the warnings on the Junfac drive shafts. | |
01-03-2014, 07:32 PM | #11 |
Like I've said, I'm new to crawlers. So yes I'll have growing pains. If this was a kyosho rb6, then I would know. I didnt know there exists a 11. Something scx10. I thought all was 12 or 12. Something. Oh well! I sent it back and requested for the honcho version! Thanks all for the quick responses |
