01-05-2014, 05:00 AM | #1 |
Newbie Join Date: Dec 2013 Location: London
| Beginners c hub question.
Hi all, sorry for stupid question. I keep seeing posts about the correct orientation of the c hubs, the kit instruction manual is not very clear on this bit (or not to me anyway) could someone explain in idiot proof language the correct way to to this please, is one ear longer than the other or something? Many thanks in advance. |
01-05-2014, 07:04 AM | #2 |
Pebble Pounder Join Date: Dec 2013 Location: MARIETTA
| Re: Beginners c hub question.
If you look at them as they would be going on to the axle you will notice how the ends will either be backwards or forwards. Make sure they are leaning backwards. This way yours tires stay straight up right when turning. If the c hubs are leaning forward your tires will lean pretty bad when turning. Just take your time and look at them and you will see the difference. Good luck |
01-05-2014, 07:05 AM | #3 |
Nice one, thank you very much So if the truck is side on, front being left, they need to be leaning right? Sorry iv made a right epic out of this.
01-05-2014, 12:54 PM | #4 |
| Re: Beginners c hub question. ^ these are Axial 8* C-hub/knuckles... so your stock C-hub/knuckle angles would not lean as far rearward. Positive caster is when the C-hubs lean slightly to the rear. Negative caster is when the C-hubs lean slightly forward. ^ looking at the top king pin screw securing (driver's side) v \ <-- bad (negative axis/caster) | <-- neutral (zero/neutral axis/caster) / <-- correct (positive axis/caster) Last edited by TacoCrawler; 01-05-2014 at 01:02 PM. |
01-05-2014, 01:14 PM | #5 |
Thanks, iv got it now |
Beginners c hub question. - Similar Threads | ||||
C hub question | XJrob | Axial Wraith | 9 | 03-29-2013 08:53 PM |
Hub Question | GravelDuster | Axial SCX-10 | 0 | 02-06-2013 01:47 PM |
C hub and axle question. | taehome | Axial Wraith | 16 | 11-16-2011 08:01 AM |
C-hub question | gac1983 | HPI Wheely King | 1 | 02-24-2009 12:04 AM |
