01-05-2014, 05:12 PM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: Omaha
| my rig specific upper/lower link combos questions/suggestions
ok,so to start off with i have recently purchased the following 3 rigs used for myself and my 2 kids. i am happy with them and they are a blast to drive on our local river bottom nature trails. no rocks here in eastern nebraska,but the rest of the fun of course. when using slightly longer upper links to rotate the axle for better pinion angle,does it have much affect on wheel base? i assume none,but if it does it must be minimal as in 1 or 2 mm if any. my question in this thread is concerning upper and lower front and rear link combinations and what i would like to accomplish with each rig. i apologize in advance for the length,but i wanted to make sure i covered all bases and info needed cherokee xj...wheel base of 11.88" or 302mm from center cap to center cap and fits the body as it sits very nicely. rear pinion angle is rotated nicely. i know i need the rear axle truss to use on the front axle to convert to 4 link,but what should i get for upper link length to get a little bit of rotation on the front pinion also (i have no idea of the length of the oem plastic Y link)? upper rear 98mm lower rear 95mm homemade upper front stock plastic Y link lower front 86mm homemade commanche...wheel base of 12.06" or 306mm from center cap to center cap and fits the body as it sits very nicely. i would like to get the rear pinion angle rotated a bit,so should i get some 98 mm upper rears to accomplish this? this has the four link conversion with the stock axle truss on the front. i would also like to get the front axle rotated a bit for better pinion angle,but have no idea on the length of the upper aftermarket aluminum links (see pic for upper links style...i would assume they are the same length as the lower front links as the pinion angle is level). suggestions for the front? upper rear 92mm lower rear 92mm upper front ??? aftermarket 4 link conversion with oem axle truss lower front 98mm 1973 bronco...wheel base of 12.38" or 314mm from center cap to center cap and fits the body as it sits very nicely. the rear pinion angle needs rotated a bit,but i don't know if i can get 112ish mm upper links or should i just use 98mm lower and 106mm upper (will the tires still line up with the wheel wells)? the front is good as i am not going to remove the aftermarket aluminum 3 link and the pinion angle is rotated nicely. upper rear 98mm lower rear 106mm upper front ??? aftermarket aluminum 3 link lower front 98mm |
01-05-2014, 08:18 PM | #2 |
Pebble Pounder Join Date: Jan 2013 Location: Raleigh, NC
| Re: my rig specific upper/lower link combos questions/suggestions
Plenty of threads here about making your own links - cheaper than buying new ones and you take the guess work out of this. Just need some threaded rod, steel or aluminum 3/16" or 1/4" tube, and rod ends - and something to cut the rod/tube with. Many will recommend this as it's cheaper and allows you to tune the vehicles exactly the way you want. On my Honcho, I used the stock lower link dimensions to make my own links the same length w/ 8/32 threaded rod, 1/4" stainless tube, and Jato ends; then I rotated the axle to the pinion angle I wanted for the uppers, measured, cut, and assembled them. |
01-05-2014, 09:23 PM | #3 |
ok,that seems simple enough...so traxxas ends are what i need,part numbers possibly? where's a good place to get the tube? |
01-06-2014, 12:27 AM | #4 | |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: my rig specific upper/lower link combos questions/suggestions Quote:
There's what ya need.NOW go and find those how to threads.....Good luck! | |
01-06-2014, 01:08 AM | #5 |
Newbie Join Date: Mar 2008 Location: Puyallup
If you want to change the length on your links you can also use different rod ends. The are a while bunch of options out there.
01-06-2014, 04:41 PM | #6 |
thanks guys...i just got all lost and caught up in all the info out there and got all bugged out
my rig specific upper/lower link combos questions/suggestions - Similar Threads | ||||
Upper and Lower Link building | Bigend777str | Axial XR10 | 6 | 11-26-2010 01:27 PM |
upper and lower link material | Tydl | General Crawlers | 3 | 09-19-2010 06:08 PM |
upper and lower link | smokediver | Newbie General | 7 | 05-06-2010 09:36 PM |
Upper link suggestions | sierradmax | Axial AX-10 Scorpion | 16 | 08-07-2008 12:25 AM |
Upper/Lower link positions | OriginalGTI | General Crawlers | 5 | 07-19-2007 08:04 PM |
