Thread: Installing ax2 transmission
Old 01-05-2014, 09:34 PM   #1
Default Installing ax2 transmission
I got an rc4wd ax2 transmission for Christmas and I don't think it is gonna be a direct fit the way my scx10 is setup. I have the battery mounted up front and as low as it will go. The transmission servo will hit the battery mount the way it sits now. I don't want to buy new batteries or move them anywhere else if I don't have to. The only option I see is to flip my skid plate and mount the tranny "backwards" so the shift servo will be on the rear of the truck. This will give me plenty of clearance and should bolt right in. Sounds like it will work, I just have to reverse my motors rotation, other than that looks like it will work no problem. Anyone have any input on doing it like that before I tear into it this week?
lowblueranger is offline   Reply With Quote
Old 01-07-2014, 03:23 AM   #2
Default Re: Installing ax2 transmission
yep flip it around backwards. my buddy had the same issue and he had to run his backwards. works great.
warren is offline   Reply With Quote
Installing ax2 transmission - Similar Threads
ax2 transmission questions CanadianKronik Axial SCX-10 2 03-01-2013 02:57 PM
Venom Creeper With AX2 Transmission DoYouEvenArticulate Newbie General 0 02-28-2013 12:03 AM
