01-07-2014, 11:30 PM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: Adelaide
| upper and lower link lengths
Ok so I don't have the tools to make my own upper links for my Dingo but I found some Axial 98mm links what I want to know is can I use the stock 91mm lower links as uppers with the 98mm links as lowers I planned on getting some traxxas rod ends and they com in a pack with four short ends and 16 long ends I was thinking I could use the long ends on the upper links to get a better pinion angle. Any thoughts that this would be ok would be great! |
01-08-2014, 12:03 AM | #2 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: upper and lower link lengths
I would suggest just using the proper length links...im guessing you maybe could use a longer rod end to make the uppers longer to change pinion angle but they make spacers also to achieve that goal and is probably a more recommended method of doing it...Sometimes a longer end can have more flex in it as well so the shorter the end in general the stronger it will be..Exceptions to the rule with quality but you get the idea.
01-08-2014, 12:09 AM | #3 |
ok kewl thanks Just been looking up the axial option parts and found this AX30549 and most of the parts already exist in the dingo kit except the 4x60mm and 4x20mm posts and some extra set screws. The links shown in the 4 link setup I think they made a typo in the upper links at the chassis I think should be AX80005-6 not -1 AX30549 instructions Last edited by pickled; 01-08-2014 at 02:22 AM. |
01-08-2014, 05:36 AM | #4 |
Any way this is what I ordered hopefully they get here at the same time the Dingo Kit arrives From A Main Hobbies Products ------------------------------------------------------ 2 x Axial 7x60mm Post (Grey) (2) (AXIA1429) = $15.58 2 x Axial 7x20mm Post (Grey) (2) (AXIA1421) = $9.78 2 x Axial M3x16mm Set Screw (10) (AXIA186) = $9.78 1 x Robinson Racing 48P Pinion Gear (16T) (RRP1016) = $3.69 1 x Axial 3x30mm Button Head Screw (Black) (10) (AXIA121) = $2.50 ------------------------------------------------------ Sub-Total: $41.33 USPS First-Class Mail International: $12.25 Total: $53.58 |
01-08-2014, 11:32 AM | #5 |
In the band for now. Join Date: Sep 2012 Location: roselle
for that kind of cash you could have made your own and use the saved cash for some upgrades
01-08-2014, 06:51 PM | #6 |
That's cool I'll have more cash next week
01-08-2014, 10:17 PM | #7 |
Newbie Join Date: Nov 2009 Location: somerville
My bottom links are 3mm longer than the top links and that has it close to the factory pinion angle.
01-08-2014, 10:27 PM | #8 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
If you go four link front and rear you could use these......... http://www.rccrawler.com/forum/chass...-scx-10-a.html |
upper and lower link lengths - Similar Threads | ||||
lower and upper link lengths | HAWAIIROCKBUSTER | Hawaii | 3 | 09-25-2012 12:44 AM |
Rockshow SS upper link lengths | jeremyfowler33 | Axial XR10 | 1 | 04-02-2012 12:28 PM |
upper link lengths for SCX10 with stock four link | oscodawave | Axial SCX-10 | 4 | 11-19-2010 08:23 PM |
Need help with upper link lengths for Moonbuggy | radical rc | EnRoute Berg | 5 | 11-04-2010 06:06 PM |
super lower and upper link lengths? | cavie98 | Superclass Crawlers | 4 | 07-21-2010 09:40 PM |
