01-09-2014, 09:49 PM | #1 |
Newbie Join Date: Jan 2014 Location: cedar rapids
| My First Scale crawler SCX10 G6
This is my first scale crawler I have background in off road racing, 1/8 e buggy and sct class. Figured this would be fun to do around my area and out in the back woods when I'm not racing. Kit is a scx10 G6, tekin fxr esc and 35t motor. Went with a solor d772 servo figured will abuse it an see what it does. At $25 nothing to lose! I put the esc and rx in the rx box. Still have to seal it to preven water getting inside. When I built the kit I did the mirror mod on the transmission. Than added super swamper boggers. Other than that it's stock. Any suggestion or input would be great hopefully get outside soon once we get above 0 degrees!!! Last edited by tlakose11; 01-09-2014 at 10:02 PM. |
01-10-2014, 07:52 AM | #2 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Re: My First Scale crawler SCX10 G6
Weight your front tires, mod. the stock shocks (go to the tips & tricks for the scx10). You might want upper aluminum links as well, and four link the front if you haven't already. Then mount your receiver box in the back and put the battery tray on the frame that is zip-tied to the shock hoops, it will lower center of graviy. Then you can put a steel rod and glue it in the drivehshafts, it will add strength. Other than that get it dirty and have fun. - axial 4x4 crawler
01-10-2014, 09:00 AM | #3 |
Rock Stacker Join Date: Apr 2013 Location: Auburn, Ca
Instead of the glued steel rod, just use the thick plastic part of an axial parts tree. Shear off all the extra plastic until you have just the rod. Then put it in the drive shaft and cut the rod 3/8" past the end, no glue. That way you can pull it out with pliers if need be.
01-10-2014, 09:13 AM | #4 |
Pebble Pounder Join Date: Dec 2009 Location: Highlands Ranch
Great Color.
01-10-2014, 10:45 AM | #5 | |
| Re: My First Scale crawler SCX10 G6 Quote:
It is complete BS to buy MIP shafts or any other brand for these trucks, if it was a traxxas slash that you race with then yeah but not a scx10 (just saying). | |
01-10-2014, 10:49 AM | #6 | |
01-10-2014, 11:04 AM | #7 | |
- Tekin gens 1 rs brushless esc - tekin gens 2 10.5t redline brushless motor - venom 3s 50c 5000 mah I am warning you though you will need full steel gear tranny, if you are confused then just pm me about all I have done to my wraith upgrades/mods. | |
01-13-2014, 02:00 PM | #8 |
just looked at my scx10 and mounting the battery tray on the frame isn't a option the steering servo is on the axle and it goes above he frame. any other suggestions? I'd like to leave the battery in the front for the weight. Thanks for the input Thanks it's pretty sweet in the sun. It's keylime pearl from faskolor Last edited by THX_138; 03-23-2014 at 08:29 PM. |
01-13-2014, 03:27 PM | #9 | |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
Recon Brick Plate - Blank Title You can also fab one up yourself and make it work in the same location. A lot of guys have done it, I'm sure you could search and find a how-to. I'm just starting my G6 build, and I'm thinking of the Jevne unit for the CMS. | |
01-13-2014, 04:48 PM | #10 |
Newbie Join Date: Aug 2013 Location: Lakewood
I'm building mine right now. My color is very similar. I'm installing a light controller for all those damn light spots on this thing. I purchased a Axial Wrangler rear bumper to house the tail lights since the G6 kit doesn't have tail light mounts. Now I have to figure out how to water proof a NVS light controller since plasti-dip is not an option. I would recommend at least a simple light controller -TowerHobbies.com | Axial LED Light Set w/Controller and Lights with a 5 light string - TowerHobbies.com | Axial 5-LED Light String White This would really help with the scale looks. I would use the 4 white led string that comes with the simple light controller to light the head lights and bumper lights and then use the 5 led light string for the light bar up top. It would look much more scale and the simple light controller is very easy install and tuck away for protection from elements. |
01-15-2014, 05:40 PM | #11 |
I'm not to concerned about lights right now my goal is to make it trail worthy and to make sure all electronics are sealed and everything work to the way I like it. Than lights will be added along with a winch and a few other goodies Went out last weekend for a little playtime just a pic of the truck Bigger view More of the crew last weekend Afternoon crawling session About fell off the edge Last edited by THX_138; 03-23-2014 at 08:30 PM. |
My First Scale crawler SCX10 G6 - Similar Threads | ||||
I want a nice scale lookin crawler! Axial SCX10 TR??? good? or no??? | yellowpasta2000 | Axial SCX-10 | 31 | 11-07-2009 09:36 AM |
