just installed moter I just installed a 27T holms hobbies moter in my axial scx 10 i havent hooked it up to the esc or reciver yet but when i push the truck with the tires on it is really hard to move and the moter wines is that normal ? |
Re: just installed moter It is hard to move because of the gearing. Its normal. Make sure you spaced the pinion away from the spur with a piece of paper in the gear, then once you tighten the motor screws turn the gear and pull the paper out. Wire up the motor and have fun. |
^ This |
Re: just installed moter Yes it's normal. |
Re: just installed moter Oh damn I didn't realize this step ill have to take moter off and reinstall it. So I put a peace of paper between pinion and spur gear? |
Re: just installed moter I don't like the paper trick. It has never worked very well for me. I just do it by feel and adjust if necessary. I rock the spur back and forth against the pinion and make sure a small amount of play is there and check it at 3-4 different locations around the rotation of the spur and then lock it down and check again. |
Re: just installed moter Quote:
Re: just installed moter if he is not got the skill set to set the mesh yet, he may best off using a pc. of cellophane from your smokes or a receipt tape from the hobby store to set the gear mesh the first few times until he knows what he is looking for??? paper seems to be to thick for the 48p gear tooth |
