01-11-2014, 05:25 PM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
| proline scaler shock shaft replacement
So one of my shafts for my scaler shocks is slightly bent. Not really a visible bend but just enough so that the shaft up and down is tight when the bottom cap is screwed all the way on. I have tried other o-rings, use green slime, all the other ones build fine, but this one shaft is tight. Switched shafts with another scaler shock, still its tight in another body/o-rings. Anyone know where to get replacement shafts without buying more of the shocks? Last edited by uclabruins89; 01-11-2014 at 05:56 PM. |
01-11-2014, 06:08 PM | #2 |
| Re: proline scaler shock shaft replacement
Update: turns out one of the bottom caps is bad. Whichever shock i put it on becomes tight when the cap is tightened down. Gonna try to file the little hole a little and see if it gets better
01-11-2014, 08:31 PM | #3 | |
| Re: proline scaler shock shaft replacement Quote:
"For replacement components to your PowerStroke shocks please call Pro-Line customer service at 1-800-899-RACE (7223)" | |
proline scaler shock shaft replacement - Similar Threads | ||||
Replacement shaft suggestions! | genki | Tamiya CR-01 | 28 | 05-16-2008 07:49 PM |
Replacement output shaft. | mrwonderful | General Crawlers | 4 | 07-31-2006 07:39 PM |
