01-13-2014, 09:56 PM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: Adelaide
| Pickleds SCX10 Dingo
I just got a parcel at my door. Dingo kit, GPM trans gears, Bluebird BMS 810MG+HS servo (looks just like the Axial stock servo), Hobbywing 80A waterproof ESC and Speed Passion 21.5T motor. Last edited by pickled; 01-14-2014 at 07:05 AM. |
01-13-2014, 09:59 PM | #2 |
| Re: Pickleds SCX10 Dingo
I've just built the trans in mirrored configuration and about to start building the chassis. Got to wait to build the axles till the beef tubes arrive!
01-14-2014, 07:14 AM | #3 |
Ok I said I was going to wait but I got impatient lol and started the build I started with the trans and installed the all metal GPM gears then moved on to the chassis |
01-14-2014, 07:17 AM | #4 |
I thought I'd help keep the diff from breaking ears by using this putty stuffed around the free space inside the diff |
01-14-2014, 07:18 AM | #5 |
How bowed are the diff housings |
01-14-2014, 07:20 AM | #6 |
pretty much together but realised I installed the chubs back to front doh! |
01-14-2014, 07:22 AM | #7 |
And now with the chubs corrected and wheels installed just need to sort the wiring out now and paint the body |
01-14-2014, 08:11 AM | #8 |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
| Re: Pickleds SCX10 Dingo |
01-14-2014, 09:19 AM | #9 |
Pebble Pounder Join Date: Nov 2013 Location: Here
| Re: Pickleds SCX10 Dingo I know the pinion is metal, but the stock Dingo spur gear is plastic? I didn't realize this. Guess I should put that on the list of upgrades to buy before I get my Dingo kit? Is that a weak point of the stock Dingo tranny?
01-14-2014, 02:58 PM | #10 |
No they are surprisingly strong bro!
01-14-2014, 04:23 PM | #11 |
01-15-2014, 05:26 AM | #12 |
Basically built now changed the battery position to up front and painted the shell needs the decals now and light buckets! |
01-15-2014, 06:12 AM | #13 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
01-15-2014, 08:08 AM | #14 |
hey 6sharky9 can you out the front chubs on the right side but upside down?
01-15-2014, 08:22 AM | #15 | |
| Re: Pickleds SCX10 Dingo Quote:
Do you have a problem with the front end? I was looking at your front pinion angle and it seems to be a bit high..that can cause geometry issues with the front wheels. Unless you use whats called clockable c hubs you shouldnt use as much of an angle like you have. You want slightly above level with the pinion angle in the front with stock c hubs which works perfectly fine Last edited by 6sharky9; 01-15-2014 at 08:34 AM. | |
01-15-2014, 08:38 AM | #16 |
01-15-2014, 08:51 AM | #17 | |
yeah it's a soft putty used to stick posters etc to walls with out marking the surface, so it's reversible! | |
01-15-2014, 09:12 AM | #18 | |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
You will change your wheel base if you lengthen the lower links. It would be best to use shorter upper links to correct angles. Your upper links should be around 3/16" or 5mm shorter than the lower links. | |
01-15-2014, 09:19 AM | #19 | |
I used whats called JB weld to hold my lockers in place...you can use an epoxy also if you wanted..just make note of where the pegs on the ring gear fit inside where the grooves from the locker also fit inside..you want the gear flush to the locker housing,..don't fill that in all the way..and make sure to clean out any excess you might get where the axle actually fits into the locker itself...Or just get the spools we talked about...they should be back in stock in a week or so..last I heard was 2 weeks about a week ago Last edited by 6sharky9; 01-15-2014 at 09:24 AM. | |
01-15-2014, 09:26 AM | #20 | |
Pickleds SCX10 Dingo - Similar Threads | ||||
SCX10 Dingo | Crawler3 | Newbie General | 2 | 06-12-2013 10:54 AM |
help with scx10 dingo | turbocivic90 | Axial SCX-10 | 14 | 03-05-2012 09:36 PM |
SCX10 Dingo | Solitaire | Axial SCX-10 | 5 | 12-06-2011 12:30 AM |
