Thread: Janfac 5mm drive shafts don't fit
Old 01-13-2014, 10:32 PM   #1
Question Janfac 5mm drive shafts don't fit
Would like advice as how to fix problem.
The Janfac 5mm driveshafts fit on my Robinson
tran. output shaft but will only go half way
on the Axial diff. shaft. [old flat blade ones
and new ones with hole--neither work ].
Any body have this problem ?
Thanks for any solutions .
Ant Chaser is offline   Reply With Quote
Old 01-14-2014, 01:23 AM   #2
T_A
Default Re: Janfac 5mm drive shafts don't fit
You can try to drill the Robinson shaft, or you can change the pin to grub (like some do with new MIPs on old shaft)
either solution is not ideal and imo you`d have more reliability with stock shaft in the trans
T_A is offline   Reply With Quote
Old 01-14-2014, 07:03 AM   #3
Mine fit very snug on the G6, I had to push them on with a decent amount of force but they did fit.
CBR74 is offline   Reply With Quote
Old 01-14-2014, 08:49 AM   #4
I would first try a small amount of grease to see if that will allow you to get the drive shaft on the the diff input shaft.
On my SCX10 I found that the input shafts were slightly deformed where the hole went through the shaft.
I ended up using #000 steel wool to to polish the shaft enough to get the drive shaft hub to go on to the input shaft. Don't use course sand paper, polishing doesn't mean grinding away the input shaft.
k7zpj is offline   Reply With Quote
Janfac 5mm drive shafts don't fit - Similar Threads
What drive shafts fit the LCC? RIG_RIDER Team Losi Comp Crawler 30 05-14-2011 05:30 PM
LCC drive shafts fit Honcho? Butcherinhd Axial SCX-10 9 04-14-2011 08:07 PM
New Drive Shafts To Fit SCX10 "TR"??? RcRecon Axial SCX-10 15 07-10-2010 07:54 AM
5mm steel custom drive shafts kazi Tamiya TLT Crawlers 11 03-11-2007 10:03 AM
