01-15-2014, 05:26 AM | #1 |
Newbie Join Date: Nov 2013 Location: Philippines
| Savox SW-1210SG on stock SCX10 steering knuckes and c-hubs
Anybody tried this servo? It's waterproof, rated 20kg at 6v. Planning to use it on my SCX10 but don't know how long the stock steering knuckles and c-hubs will last. What do you guys think? Should I go ahead and install it on my stock steering assembly or should I upgrade first to alloy knuckles and c-hubs? I already have a BEC on hand and currently running a 10kg servo on stock steering assembly. Thanks! Sent from my iPhone using Tapatalk |
01-15-2014, 05:31 AM | #2 |
Pebble Pounder Join Date: Jan 2014 Location: Adelaide
| Re: Savox SW-1210SG on stock SCX10 steering knuckes and c-hubs
yeah I'd install it and see how long it is till it breaks the chubs lol but seriously if you're worried about you chubs just adjust your endpoints so it can't go past full lock!
01-15-2014, 05:41 AM | #3 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Savox SW-1210SG on stock SCX10 steering knuckes and c-hubs |
01-15-2014, 06:24 AM | #4 |
Test and worry about it later hehe! It's a practical idea but from where I live, Axial parts is very scarce and I have to get it online which takes a few weeks before it arrives.. the wait spoils the fun out of it. I'll make sure my endpoints are adjusted properly. Last edited by entaro; 01-15-2014 at 06:27 AM. |
01-15-2014, 06:28 AM | #5 |
01-15-2014, 06:55 AM | #6 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
You can break the stock knuckles with a stock servo if you don't drive it with it with respect or have an accident. Im using a servo with 177oz of torque and have had no issues with breaking the stock knuckles..Depends on how you drive it for the most part. You may roll down a hill and the edge of the wheel catches a rock and it breaks it..anything can happen...you may have enough power when your tires get wedged that you snap it in two trying to push the rock out of the way or lift your truck on servo power. Just install it and drive it...If you break one due to power then you know you need better ones..If you break because of an accident then you can either replace it with stock or upgrade anyway. Last edited by 6sharky9; 01-15-2014 at 07:00 AM. |
01-15-2014, 07:45 AM | #7 |
^you have a good point there bro. Well, I drive carefully for the most part but accidents can do happen. I guess I have to use it to find out.. Time to get those alloy knuckles and c-hubs just in case. Thanks! |
01-15-2014, 08:31 AM | #8 |
01-15-2014, 01:52 PM | #9 |
Quarry Creeper Join Date: May 2010 Location: scotland
i have the 0231 wp savox and i havent had any problems with c-hubs or knuckles but i have only used it once but my mate has been using the same servo as mine for a few month now with no probs
01-16-2014, 06:24 AM | #10 | |
I'll run the sw-1210sg on 5v.. That should put out 222 oz. of torque which is a bit closer to 0231 on 6v in terms of torque output. I hope the lower voltage will help my stock knuckles and c-hubs last longer until I get better ones. Thanks! Sent from my iPhone using Tapatalk | |
01-16-2014, 08:34 AM | #11 | |
| Re: Savox SW-1210SG on stock SCX10 steering knuckes and c-hubs Quote:
01-17-2014, 08:59 PM | #12 |
^Thanks for the heads up bro! I'll keep that in mind. How about a longer bolt, washer and nut inside the housing to secure the c-hubs? That would be more secure.. however, installing the nut via the c-hub opening will be quite a challenge. -- Cheers! |
Savox SW-1210SG on stock SCX10 steering knuckes and c-hubs - Similar Threads | ||||
aluminum c-hubs and knuckes | iluvny081 | Venom Creeper | 9 | 01-31-2011 09:27 AM |
