01-15-2014, 04:24 PM | #1 |
Newbie Join Date: Jan 2014 Location: fallbrook
| steering?, horns?, what do you run on the G6
Currently using the hitec 5646wp, I thought that this Hitec being a metal geared digital servo would have come with an aluminum servo horn. (which it didn't) from Towerhobb's... So i threw on the plastic axial one from the tree, which I thought would be okay, but the plastic one doesn't fit it very well at all. I'm sure its going to just strip that thing quick if the screw happened to loosen even a bit. I do have the servo limited right as the knuckles bind so that should help. Should I just get the Axial HD horn for the Hitec? I am planning on doing a CMS sometime in the future... is there a better horn for a CMS in mind? One more thing! What is a reasonable method to get some more turning radius? I know the servo can go quite a bit further in both directions. |
01-15-2014, 04:36 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Carson City, NV
| Re: steering?, horns?, what do you run on the G6
Robotronics for the horn. Best way to get more steering is to do the XR mod with the rcbros burly splined tubes and put on some wraith chubs and knuckles. |
01-15-2014, 04:51 PM | #3 |
Thanks for the Info ion, what length on the servo horn? im guessing the "short" one? UPDATE: yeah iam going to get a new horn, messing around in my yard light crawling and running wide open i came super close to losing the screw out of the servo haha. now where did i leave my loctite! Last edited by mikesmyth11; 01-15-2014 at 07:14 PM. |
01-15-2014, 07:32 PM | #4 |
| Re: steering?, horns?, what do you run on the G6 |
01-20-2014, 06:18 PM | #5 |
yeah i guess you cant go wrong with the one kinda made for the vehicle. i did some pretty serious crawling at superstition mountain in so cal. while out for a riding trip, didnt have any problems with the stock plastic servo horn once i tightened it down real good with that "lock" washer, i could have gone with a better servo with the weight i have, maybe i will put the hitec 5646wp on my slash and go for a more torque option. |
01-21-2014, 09:10 AM | #6 |
Pebble Pounder Join Date: Dec 2009 Location: Highlands Ranch
I use the Axial HD servo horn...on all of my crawlers. If you don't want to lay out the extra cash for the Burly Tubes and the XR10 mod. You can do what I did to the steering on my G6. Vanquish hubs and chubs and a suicide steering set up. I get plenty of steering out of this set up. Red Cow...G6 SCX10 |
01-21-2014, 04:14 PM | #7 |
very nice setup mike, i also like how it seems to be really simple. i like the idea of a chassis mounted servo, but i would rather have it turn better, and in return, it will perform better. plus more clearance with that "suicide" setup. thanks for the advice. |
steering?, horns?, what do you run on the G6 - Similar Threads | ||||
Bec hook up to run a steering servo | Gmader1 | Electronics | 1 | 10-09-2012 11:17 PM |
OTA vs BTA steering, what do you run? | crawl-o-matic | General Crawlers | 3 | 08-13-2011 06:26 PM |
steering horns | jcr0224 | Newbie General | 5 | 07-18-2011 11:45 AM |
What steering servo should I run? | Desert Camo | Newbie General | 9 | 12-27-2009 02:33 PM |
servo horns | Dickie691986 | General Crawlers | 19 | 03-23-2009 06:40 AM |
