01-16-2014, 08:47 PM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: Folsom, CA
| Back At It Wrangler JK Build
I figured it was time to get back in to the scale Rc world. I ended up selling my rigs last year. Everyones JK builds made me want my own haha. Picked this up off flebay for 350. Felt like I stole it for that price. Mint JK Ran only a few times indoors. 4 linked flebay CMS Gmade shocks RC4WD front and rear bumpers RC4WD winch Axial 1.9 Beadlocks No name motor Axial Chubs Axial Knuckles Axial links Ive got a few things still waiting to be delivered. Forgive the crap Iphone photos Last edited by Case182; 01-16-2014 at 11:59 PM. |
01-16-2014, 08:50 PM | #2 |
| Re: Back At It Wrangler JK Build
Ran into a problem with the CMS kit the previous owner has installed. The horn hits the steering link, and with the servo moved further back on the mount it hits the axle. This results in less than half in inch of front suspension travel. Im going to switch back to an axle mounted servo which should free up all the travel. Last edited by Case182; 01-17-2014 at 12:06 AM. |
01-16-2014, 10:01 PM | #3 |
Just finished installing new custom links. |
01-17-2014, 08:46 PM | #4 |
Got my new beadlock rings in today from Gearhead Rc. They really improve the look of the stock Axial beadlock wheels. Also got the stock suspension put back on. |
01-17-2014, 09:07 PM | #5 |
RCC Addict Join Date: Nov 2004 Location: union
Awesome job on the links, looks like they turned out very clean. |
01-17-2014, 09:28 PM | #6 |
| Re: Back At It Wrangler JK Build |
01-18-2014, 09:07 PM | #7 |
Mocked up some Junfac spacers..... Have to actually cut the wheels for them to lock into place. So im getting rid of those. Also mocked up my motor to the stock trans and ended up with some fitment issues. Not sure what i'll do. |
01-19-2014, 07:43 PM | #8 |
Anyone have any idea on fitting the motor?
01-22-2014, 09:44 PM | #9 |
Guess no one has an opinion..... Picked up one of Savox's waterproof servos. |
01-22-2014, 11:53 PM | #10 |
Rock Stacker Join Date: Jan 2014 Location: Utah, USA
Hey there bro. I like how your Jeep is looking. I saw your post and was wondering what isn't fitting with the motor? Are the screw holes lining up? Is it how far out the motor shaft is? I'm personally having a hard time trying to figure out how to help just by the pictures alone. If you could give a bit more info, maybe it might help us out a little to get the right ideas flowing your way. Keep up the awesome work on this bro. It's looking sweet. |
01-23-2014, 01:45 AM | #11 | |
| Re: Back At It Wrangler JK Build Quote:
The motor shaft is super close to the spur gear. Also the back of the motor can sits up higher on the front upper link nut. Ill try sanding the top of the rod end and see if that changes anything. The motor shaft will probably be closer with the Slash RR Spur gear when I upgrade. Not sure if the spur is actually larger or not Last edited by Case182; 01-23-2014 at 02:57 AM. | |
01-23-2014, 06:36 AM | #12 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
Just curious...why are you trying to put a velineon motor in a crawler / scaler?
01-23-2014, 06:16 PM | #13 |
Was trying to keep the build cost low and use what I had laying around. And with the tqi radio you can adjust the motors output on the fly. Even Harley had one in his wraith for a bit.
01-23-2014, 07:11 PM | #14 |
Got my Harley Vanquish transmission in today. |
01-23-2014, 07:47 PM | #15 |
Pebble Pounder Join Date: Jan 2014 Location: Staten Island
i see that CMS mount you had in there is the same one i tried using with the same issues, the company really should put a disclaimer or do some fitment before putting (that) product out. Hope you can get that big ass motor working with that sweet new transmission!
01-23-2014, 07:49 PM | #16 |
Also the quarter inch links are bada$$ why did you go back to axial suspension though?
01-23-2014, 07:56 PM | #17 |
01-23-2014, 10:24 PM | #18 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
The steering link on the front axles needs to be dropped down were the lock nut is. Thats probably why it has limited travel. Bottom link should look like this. Last edited by MaxxPain; 01-23-2014 at 10:31 PM. |
01-23-2014, 10:36 PM | #19 |
I was getting limited travel due to the no longer installed CMS kit that came with the truck. I'm getting full travel no with the axle mounted servo, even with the link mounted where it's at now. If I were to put it on the bottom it'll hit the pumpkin.
01-23-2014, 10:57 PM | #20 |
Are you using these ball ends. These offset the link and give you more room. |
Back At It Wrangler JK Build - Similar Threads | ||||
CC-01 Wrangler is back !!! | prosavage | Tamiya XC/CC01 | 0 | 10-12-2011 05:54 PM |
NB TJ Wrangler Build | scrapen | 1.9 Scale Rigs | 27 | 09-03-2010 06:14 AM |
Help with 1.9 JK Wrangler build | JKJim | Newbie General | 3 | 12-02-2009 09:49 AM |
My Wrangler JK Build | dbb888 | 1.9 Scale Rigs | 54 | 03-18-2009 12:28 PM |
Yet another NB wrangler build | mr.allthat | 1.9 Scale Rigs | 8 | 05-29-2008 12:29 PM |
