01-20-2014, 01:25 AM | #1 |
Newbie Join Date: Oct 2013 Location: Poland
| Front axle jumping?
Hello everybody, Please send suggestions what to do with it? |
01-20-2014, 05:22 AM | #2 |
Pebble Pounder Join Date: Dec 2013 Location: MARIETTA
| Re: Front axle jumping?
Sounds like a binding issue. If you are running the stock dog bones check the joint at the knuckle when turning and make sure everything is staying in place . That is most likely where you will find a problem.
01-20-2014, 06:28 AM | #3 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Front axle jumping? |
01-20-2014, 07:57 AM | #4 |
Thanks - will inspect that tonight!
01-22-2014, 12:44 AM | #5 |
Thanks - inspected dogbones tonight and they look a little eaten - very lightly. It seams that during a turn the dogbone rod just below the ball binds with the axle cups - the cut-outs that dogbones slide into. Second picture shows it even more. Do you think I could dremel the cups a little bit on the inside to solve it? |
01-22-2014, 12:52 PM | #6 |
Somehow my posts don't make it the first time ... Dogbone is a little eaten just below the ball end. It seams that it is binding during a turn with the slots in the axle cup. Do you think I could dremel it a little?
Front axle jumping? - Similar Threads | ||||
Narrowing front Wraith Axle for front of scx10 | rusty577 | Axial SCX-10 | 12 | 02-02-2013 10:30 PM |
LNC front axle teardown/axle shaft removal guide? | LowLock | Team Losi Comp Crawler | 1 | 05-22-2011 09:31 PM |
front steering linkage behind front axle kit? | slip408 | Axial AX-10 Scorpion | 8 | 09-14-2008 01:16 AM |
