01-20-2014, 12:37 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: brockville
| 4 linking the front jeep rubicon scx10
Are the front lengths the same measurements as the rear when 4 linking the front? I'm using the stock plastic links as a template,making them from all thread and 5037 rod ends
01-20-2014, 12:42 PM | #2 |
Specifically using eye to eye lengths to keep it easy
01-20-2014, 01:08 PM | #3 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: 4 linking the front jeep rubicon scx10
When using the Axial 4-link truss in the front the upper links are 3/16"-1/4"(5mm- 6mm) shorter then the lowers.
01-20-2014, 01:11 PM | #4 |
| Re: 4 linking the front jeep rubicon scx10 |
01-20-2014, 01:22 PM | #5 |
So i can basically mirror the rear then?
01-20-2014, 01:25 PM | #6 |
I'm sorry k7 how you have it written i don't understand...so 119 rear upper 130 lower is what your saying?
01-20-2014, 01:26 PM | #7 |
Front lower 122 front upper 104?
01-20-2014, 02:13 PM | #8 |
These are the stock lengths taken from the Axial 12.3 in link set. The front upper links are 104mm and the front Lower Links are 122 mm. The rear upper links are 119mm and the rear lower links are 130mm. The stock lengths don't clock the axle enough to get a good drive line angle. I would follow R2J's advice and make the upper links about 1/4 shorter than the lower ones. Last edited by k7zpj; 01-20-2014 at 02:16 PM. |
01-20-2014, 02:17 PM | #9 |
Ahh awsome thank you! Couldn't find that info :-)
01-20-2014, 03:15 PM | #10 |
So i should stick with the stock lower lengths and take 1/4 off that measurement for the uppers.. is this the same with the rear as well then?
01-21-2014, 08:31 AM | #11 |
Rock Stacker Join Date: Feb 2013 Location: NC
STRC just put out a 4 link plate for the front. No idea how it is but maybe could look into it.
01-21-2014, 11:26 AM | #12 |
RCC Addict Join Date: May 2008 Location: Southern,WV
4 linking the front jeep rubicon scx10 - Similar Threads | ||||
newbrite jeep scx10 rubicon | jkaddict | Newbie General | 2 | 01-09-2014 07:35 PM |
Four Linking The Front | muddeprived | General Crawlers | 29 | 06-16-2006 09:53 AM |
