Thread: Proline 2 door Wrangler body on SCX10 Wrangler
Old 01-21-2014, 07:39 PM   #1
Default Proline 2 door Wrangler body on SCX10 Wrangler
I drive a 2 door Wrangler and I thought it would be cool to make my SCX the same as my truck. As you probably all know, Proline makes a 2 door Wrangler body but it seems the wheelbase is slightly shorter then the Wrangler SCX10's. Is there any way to install that body onto my SCX?
IonicRipper is offline   Reply With Quote
Old 01-21-2014, 07:46 PM   #2
k7zpj's Avatar
Default Re: Proline 2 door Wrangler body on SCX10 Wrangler
The Proline 2dr JK body fits the Dingo wheel base. You change out the links and move the shock hoops to the Dingo locations. There is a extended body post that you use for the rear body posts.
k7zpj is offline   Reply With Quote
Old 01-21-2014, 07:51 PM   #3
And the frame wont be interfering with the body?
Old 01-21-2014, 07:59 PM   #4
No interference at all, fits perfect if you switch the links to the Dingo wheelbase.
Nightmare702 is offline   Reply With Quote
Old 01-21-2014, 08:01 PM   #5
Awesome, thanks guys!
Old 01-22-2014, 12:30 AM   #6
It fits great.
Sent from my XT907 using Tapatalk
norcalmk2 is offline   Reply With Quote
Old 01-22-2014, 04:14 PM   #7
In order for this to work, do I have to change every control arm? Because I only have 4 arms and 1 V-spaped link in the spare parts bag...
Old 01-22-2014, 06:25 PM   #8
k7zpj's Avatar
You will have to buy/build links to replace all of the 12.3 inch wheelbase links with 11.4 inch wheelbase links. They are not included with the Wrangler.
While you are at it, you should 4-link the front.
The 11.4 inch link set instruction lists all of the parts needed including 4-link
http://docs.axialracing.com/instruct...Set_11.4in.pdf
R2J Stainless Steel links are a good option which cost just a little more than the Axial links.
http://www.rccrawler.com/forum/chass...-scx-10-a.html
Old 01-23-2014, 12:10 PM   #9
As an alternative, you can go with the Dingo links and just add some spacers to the links to increase the wheelbase to get the wheelbase close enough.
Trump1 is offline   Reply With Quote
Old 01-23-2014, 03:00 PM   #10
What if i used the shorter links that came in the parts bag and took the links from my friend's Wrangler parts bag?
Old 01-23-2014, 05:52 PM   #11
k7zpj's Avatar
If you want to use the plastic links then you would use AX80043-2 for the lower links and AX80043-4 for the upper links.
The AX90012 TR Dingo instructions shows the plastic link setup.
http://docs.axialracing.com/instruct...84%A2_Body.pdf
The plastic links will really flex and you won't get much crawling out of them before they need to be replaced.
Old 01-23-2014, 06:18 PM   #12
Any links designed for the Dingo will be to short. The Dingo's wheelbase is 11.4 inches. The Pro-Line Wrangler's wheelbase is 11.8 inches.
I suggest making your own links or the following:
- Buy the aluminum link upgrade kit for the Dingo.
- Buy aluminum spacers.
- But longer grub screws.
Here's my Wrangler Rubicon:
Old 01-23-2014, 06:41 PM   #13
I was able to get the WB down to 298mm by switching the links around and using the shorter ones that come in the parts bag. Close enough
Old 01-23-2014, 08:27 PM   #14
That's good.
Proline 2 door Wrangler body on SCX10 Wrangler - Similar Threads
proline 2 door Jeep Wrangler body on ar60 axles parker88 Paint and Body 3 05-11-2013 09:12 PM
New Proline Jeep Bodies - '92 XJ Cherokee, '09 JK Wrangler 2 door. monkeyracer General Scale Talk 5 04-26-2010 05:00 PM
4 door wrangler body rockgear General Scale Talk 12 04-30-2009 05:45 AM
