01-28-2014, 12:47 PM | #1 |
Newbie Join Date: Aug 2005 Location: Annapolis
| SCX10 Dingo Kit Center Diff assembly issue (maybe wrong parts?)
Hello - long time lurker here. I'm putting together an Axial SCX10 Dingo kit, and I've hit a snag assembling the center diff (the one in the tranny). According to the instructions the following four parts should be assembled together: AX30435-003 (Out-drive half) AX30435-001 (Out-drive half) AX80010 (Center Diff Gear) AX80009[5] (Plastic Shaft) It looks like the center shaft (AX80009[5]) is supposed to fit through the diff gear (AX80010) and into the out-drives so they can be sandwiched together on the diff gear. In my kit, the plastic shaft is too large to fit into the metal out-drives, so the out-drive halves are not close enough together for the screws to reach. Plus - the diff gear would wobble unless the center shaft and out-drives are connected. Here are some photos showing the parts that came with my kit: So I have two questions: 1. Do you agree that something is wrong here, or is this operator error? 2. Has anyone else seen this issue? Thanks. -R Last edited by RacerR; 01-28-2014 at 01:04 PM. |
01-28-2014, 01:22 PM | #2 |
Newbie Join Date: Dec 2013 Location: NoVA
| Re: SCX10 Dingo Kit Center Diff assembly issue (maybe wrong parts?)
i had the same issue. i left the piece in question out. because there are no balls in that diff, and the 3 screws goes thru the center diff gear. it's supposed to be 100% locked anyways. thus far i've had no issues. but i'd be interested to hear what the experts say. |
01-28-2014, 02:02 PM | #3 |
Newbie Join Date: Jun 2012 Location: Indianapolis
I had the same problem. I left it out. I have had zero problems with mine.
01-28-2014, 02:33 PM | #4 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
I left it out as well. It was a new step since the last time I built an SCX. I also replaced the final gear with a machined unit from Robinson Racing.
01-28-2014, 02:39 PM | #5 |
That plastic piece was meant to go in between the old aluminum outdrives. Not sure why they still include it or haven't updated the manual. The newer steel outdrives are plenty strong whereas the old hollow aluminum ones would shear off if the wind caught it just right.
01-28-2014, 02:39 PM | #6 |
The spacer was used with the old style out-drives with the flat for the old style drive shafts. If you look at the JK or G6 kit instructions, the spacer has been removed from the step. Looks like the spacer got missed when they updated the instructions for the Dingo. I would let Axial support know about it. |
01-28-2014, 04:11 PM | #7 |
Thanks for the responses. I'll send an email over to Axial to inform them in case they are not aware of the misprint. -R |
03-31-2014, 11:42 PM | #8 |
| Re: SCX10 Dingo Kit Center Diff assembly issue (maybe wrong parts?) Quote: |
04-01-2014, 03:38 AM | #9 |
Rock Stacker Join Date: Jan 2014 Location: Utah, USA
The spacer isnt needed at all. Ive recently built both the G6 kit and this dingo kit and its a misprint. Well they haven't even updated the manual for the dingo at all. They updated the outdrives and thats it on it. I hope this helps out. ;)
12-30-2014, 08:08 PM | #10 |
I joined the Band! Join Date: Dec 2014 Location: Earth
My new Dingo kit has the same manual and unusable part reference. There are a few other errors in the manual as well, not really a bug deal but annoying none the less. This bushing is supposed to help keep the diff gear centered with the outdrives, apparently they chose to change the outdrives and that bushing is no longer used. I'll be making a bushing to fit the outdrives and gear next time I have to go into the transmission. I believe it needs this part for the transmission to operate smoothly and quietly. Without it the gear can be bolted down a little off center causing a little noise and a little drag in the transmission. Of course it may not make any difference at all after the truck has a few packs through and everything in the drivetrain settle in a bit.
SCX10 Dingo Kit Center Diff assembly issue (maybe wrong parts?) - Similar Threads | ||||
Please critique my parts list for scx10 dingo kit | BubbaEinstein | Newbie General | 12 | 03-12-2012 04:55 PM |
Did I order the wrong parts? Knuckle/stub issue | lowslowTJ | Axial Wraith | 4 | 10-09-2011 08:29 PM |
