02-05-2014, 08:44 AM | #1 |
Newbie Join Date: Mar 2012 Location: sweden
| Brushles scx. Yes/no
Looking to upgrade my scx 10 to brushless. Would you say that a 18,5T motor would work on the stock setup or do I need to get a new pinion gear. Or is it gonna be all wrong altogether? The resin I am asking is that I have a Novak 18,5t in my losi comp crawler and I am looking to sell that chassi, so I figured why not swap over the motor to the scx. I do mostly light trail crawling with the rig so sped isn't a must but hey it wouldn't hurt. |
02-05-2014, 09:05 AM | #2 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Brushles scx. Yes/no Quote:
If you want some speed an 18.5 may not do it for you..Maybe a 13.5 if you want some speed..Gearing it down some to compromise for low speed control and still have good speed is always a welcome change. | |
02-05-2014, 11:12 AM | #3 |
Quarry Creeper Join Date: May 2013 Location: on top of the rocks
No !!! don't do it. The brushless works well in a lcc because of the worm drives but for the SCX axles its not so good as a brushed system. The brushless system in a SCX needs to be sensored and don't get it anywhere near water.
02-05-2014, 11:19 AM | #4 |
Pebble Pounder Join Date: Jul 2013 Location: El Centro
Yes, it would work. You can waterproof the motor by covering the sensor board in the motor with liquid tape. -Corrupt |
02-05-2014, 11:24 AM | #5 |
Newbie Join Date: Feb 2012 Location: Lexington
I run a mmp pro with a 9.5 Lrp sensored and 2 speed from rc4wd on my scx frame. I have no issues great crawler gear and short course fast 2nd lol. I also have used brushless on scx transmissions's but recommend sensored. Sensorless to me acts like you have no control throttle response sucks basically. I see nothing wrong with brushless sensored system in a scaler ;)
02-05-2014, 11:31 AM | #6 |
It is a sensored motor in the LCc of course so that would not be a problem. I was thinking more in the lines of " I don't want to ruin something on the truck becous there is to much power from the motor..." But I guess I can run it responsibly to start with. ^^
02-05-2014, 03:30 PM | #7 |
Newbie Join Date: Mar 2009 Location: Monkton
I'm running a MM Pro with a Tekin Redline 17.5 on 3s with stock gearing (14/87). Works fine.
02-05-2014, 03:31 PM | #8 |
Thanks
02-05-2014, 03:39 PM | #9 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
I'm running a Holmes Hobbies 11T crawlmaster pro , 87/16 on 2s and it's plenty fast on 3s it's pretty silly . I'm staying brushed cause I'm bound to hit the water. To each his own,most of all HAVE FUN! tear it up and rebuild different next time.
02-05-2014, 04:27 PM | #10 |
Rock Stacker Join Date: Nov 2011 Location: Huntsville, Al
I run sensored brushless in everything. I love it. It stays cool, has gobs of wheelspeed, and more torque than you'll ever need. Parts are going to break eventually either way. Your 18.5 might not have much wheelspeed so it shouldn't result in many broken parts. If you want more a 13.5 or 10.5 will give you a good boost in speed with little loss in torque and battery life. Ben |
02-05-2014, 04:41 PM | #11 |
Quarry Creeper Join Date: Oct 2011 Location: U.S.A
Im running a Tekin RS with a brushless 13.5 and love it! I had a 17.5 in it and it was a little to slow for my likings.... 13.5 is the way to go!
02-05-2014, 06:12 PM | #12 |
Pebble Pounder Join Date: Jan 2009 Location: Parkesburg
I run a Hobbywing Juststock esc and Reedy 17.5 sensored motor, stock SCX gearing and it has enough torque and wheel speed to suit me. I love brushless power systems.
02-05-2014, 06:53 PM | #13 |
MMP + Pro4 + Conformal Coating = WIN! Techspray Products, Techspray | Kimco - TechSpray 2108-12S Turbo-Coat Acrylic Conformal Coating, 12 oz |
02-05-2014, 07:00 PM | #14 | |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Brushles scx. Yes/no Quote: | |
02-05-2014, 08:14 PM | #15 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
like to know more about that as well. i have seen the brush on as well. not a spray
02-05-2014, 09:38 PM | #16 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
I got two Sensored Brushless SXC10's running Castle MMP esc's and 13.5 T Tekin Redlines motors, bought aluminum tranny cases, and 32p spur and pinion gears, Robison racing metal tranny gears, Axial metal drive gears and hardened steel output shafts in the tranny's and hardened steel input shafts in the axles, they are the thru hole type so there perfect for my MIPS CVD's Center drive shaft kits. I have not installed under/over drive in axles, not sure if needed yet. and love them both but need to water proof them cause I don't run them in wet conditions ever, but that's just me.
Brushles scx. Yes/no - Similar Threads | ||||
Brushles system options. | CrazyNick | Formula Offroad | 2 | 03-02-2012 10:15 PM |
Not sure if I should go the 21T Titan or Losi 17.5 brushles route?? | MDcrawler72 | Team Losi Comp Crawler | 24 | 06-16-2009 07:43 PM |
holmes brushles motors, which one? | seanhawk | Electronics | 3 | 02-04-2008 01:21 PM |
brushles & waterproof | Dustyk | Electronics | 9 | 04-12-2007 11:45 PM |
