02-06-2014, 01:21 PM | #1 |
Newbie Join Date: Feb 2013 Location: Sutton
| Scx10 wheelbase
Hi all I've got a the above truck with a wheelbase of 11.4 inches, I've shortened it. Will this be short enough for a hard body landrover d90? It says there 277mm so that's a bit smaller than my truck would I get away with it or need to make my wheelbase even shorter. Many thanks |
02-06-2014, 05:09 PM | #2 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Scx10 wheelbase
give it a try , that's how you will know
02-06-2014, 06:08 PM | #3 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: Scx10 wheelbase
Well...messure your wheelbase and compare it to the wheelbase of the body. If the wheelbase of the body is 277 mm and the wheelbase of your truck is 11.4 inches or 289.56 mm. Then your wheelbase is 12.56 mm to long. So yes you'll have to make it shorter.
02-07-2014, 11:18 AM | #4 |
| Re: Scx10 wheelbase
What wheelbase have other people used for the scx10 with the d90 hard body?
02-07-2014, 11:30 AM | #5 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Scx10 wheelbase
If the body is X amount of wheel base then all of them will be the same wheel base if they used the same body you have or want to use. Wheel base should be measured center to center of the wheel openings. You have to put the body on and see how far you have to bring the rear in for it to fit properly...You'll more than likely have to make custom links. The shortest wheel base scx10 is the Dingo at 11.4" inches...The G6 is 12.0 and the honcho/rubicon is 12.3 Last edited by 6sharky9; 02-07-2014 at 11:33 AM. |
Scx10 wheelbase - Similar Threads | ||||
Axial SCX10 wheelbase questions | edge_pilot | Axial SCX-10 | 12 | 08-24-2015 09:40 PM |
Extending the scx10 wheelbase. | Paul1234 | Axial SCX-10 | 7 | 09-16-2013 10:52 AM |
Axial SCX10 Wheelbase? | jasons36 | Newbie General | 0 | 03-28-2010 08:50 AM |
Stretching wheelbase on my SCX10 TR | Davenow | Axial SCX-10 | 5 | 02-15-2010 11:04 PM |
Wheelbase on the Tamiya YJ, on SCX10? | treeafodo | General Scale Talk | 1 | 06-05-2009 04:48 AM |
