02-08-2014, 08:44 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: UK
| Wroncho link help? I have searched honestly... :-(
Hello. The rig runs superb in every way apart from on steep gradients the left front tire as looking when I'm stood behind it lifts causing it to unbalance. I have flipped the transmission but this did not seem to fix it and caused the drive shaft to sit at a worse angle so I put it back. I have been reading about mirroring it but the tire that is lifting is the side with the motor on? So moving the weight would not resolve from what I gather as it is in the correct place. I have added some pics. Hope this helps. Sent from my HTC One X using Tapatalk |
02-08-2014, 10:15 AM | #2 |
Pics fine thanks. Do you think my links are the cause? Your drive shaft sit the same as mine. Do you get lift/torque twist? Sent from my HTC One X using Tapatalk Last edited by o0wiz0o; 02-08-2014 at 10:51 AM. |
02-08-2014, 11:35 AM | #3 |
Where's the reply gone! Haha Sent from my HTC One X using Tapatalk |
02-10-2014, 01:42 AM | #4 |
| Re: Wroncho link help? I have searched honestly... :-(
Am getting there. After reading some more on general torque twist remedies I have... - Stiffened the opposite shock to the corner that lifts. - Lifted the rear end a little so squat affects it less - Moved the heavier of the two front wheels on to the corner that lifts (One suffers water ingress and one does not). I know the only reply that was here disappeared but as the post is still here I thought the info maybe useful to someone who stumbles across it. Ta. |
02-10-2014, 07:47 AM | #5 |
I wanna be Dave Join Date: Nov 2007 Location: roseville
I run my wroncho low and the outputs are on the same side(do not run across ,straight shot. also I run a rear sway bar(hr for a wraith) I have no twist. thread(home depot rental truck) Last edited by zonkerd; 02-10-2014 at 07:51 AM. |
02-10-2014, 07:59 AM | #6 |
Thanks man. I'll go check your build. (The truck looks ace) |
02-10-2014, 10:14 AM | #7 |
Running with under drive gears in the rear diff and stock or over drive gears in the front diff will help with the torque twist.
02-10-2014, 10:21 AM | #8 |
Ah that's good to know. I was thinking of over driving the front. Help her crawl even better. Sent from my HTC One X using Tapatalk |
02-12-2014, 12:54 AM | #9 |
Okay....5hrs of tinkering! She is now sat a lot lower (similar to Zonkered) and looks a lot better. The Torque twist is better until I do fast-ish right hand turns or climb at certain angles. I have read so much stuff on this now! I think my next options are: - Stiffen the opposite rear shock - weight the front corner that lift. (This hides the Torque twist) - See if I can mod a rear ARB. I don't really want to loost rear flex though. I have also wondered if using a panhard would help? Thanks |
02-12-2014, 01:54 AM | #10 | |
RCC Addict Join Date: Sep 2009 Location: sacramento
| Re: Wroncho link help? I have searched honestly... :-( Quote:
02-12-2014, 02:20 AM | #11 |
Hi Dan. I am not. Both yourself and Zonkerd are and have recommended them so I'm going to look into it. Thanks. |
02-12-2014, 11:55 AM | #12 |
I've won! Complete rear droop and fixed the front upper links. Slung it real low like Zonkerds for low COG. :-) Thanks or the help folks. :-) Last edited by o0wiz0o; 02-12-2014 at 11:59 AM. |
03-12-2014, 10:14 AM | #13 |
Full Wroncho now... Sent from my HTC One X using Tapatalk |
Wroncho link help? I have searched honestly... :-( - Similar Threads | ||||
Wroncho Link Help | UnlimitedJDB | Axial SCX-10 | 38 | 03-24-2017 12:36 PM |
ive searched and searched and read now the question what grease to use in a ax10 tran | 89lxmorepower | Axial AX-10 Scorpion | 23 | 09-16-2012 10:09 AM |
If Santa Answered His Mail Honestly..... | Echodawg | Chit Chat | 10 | 12-22-2007 07:58 AM |
Honestly, are modern teens this stupid? | Robb | Chit Chat | 111 | 07-08-2007 09:09 AM |
Searched and searched...TXT axle/tranny ratios. | JasonInAugusta | Tamiya Txt-1 and Juggernaut | 2 | 01-30-2005 10:06 AM |
