02-08-2014, 08:49 PM | #1 |
Pebble Pounder Join Date: Aug 2007 Location: South Central Mississippi
| SCX10 4 Wheel Steering parts
Will a Wraith servo plate fit on the SCX10's axles? I want to use the shorter one for mounting on the rear where the 4 link is at. Got the other parts figured out, I think, except the rear brace. I guess I'll cut it up like most do. It looks like the front mount would work great for the rear also but that's an extra 18 bucks because it includes the trans center mount tree also. |
02-08-2014, 10:32 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: SCX10 4 Wheel Steering parts
Yes it will. By brace, do you mean truss? If so, yes the 4 link truss will work on both the front and rear axle. |
02-09-2014, 12:32 PM | #3 |
No, I'm talking about the front chassis brace that allows the servo to got through it and the rear chassis brace that has the X in it. They both help hold the shock hoops on chassis. I was wondering if the front one will fit rear perfectly. I measured (while still on chassis) and got about 36 mm between bolt holes. But buying just that one requires buying the center trans chassis plate along with other parts ($1. Thanks for letting me know about the Wraith servo plate. |
02-09-2014, 12:57 PM | #4 |
RCC Addict Join Date: May 2008 Location: Southern,WV
You should try the wanted section before buying all the braces.Someones bound to have one.
02-09-2014, 01:14 PM | #5 |
I have the brace you are looking for I think...I had to remove it when I installed the rc4wd CMS setup. you are talking about the brace right between the shock hoops in the front right? If so, PM me your address and I will send you this brace I have. I looked and it seems to be the same bolt pattern as the rear and looks like it will directly bolt in with no isue Last edited by allanon1965; 02-09-2014 at 01:16 PM. |
02-23-2014, 08:27 AM | #6 | |
Thanks very much Allanon1965. Trimmed a little and it worked like a charm! Quote:
02-23-2014, 08:31 AM | #7 |
cool, ya got any pics? |
SCX10 4 Wheel Steering parts - Similar Threads | ||||
RX10 rear wheel steering pictures and parts list? | pmadrid13 | Axial XR10 | 6 | 06-24-2012 10:10 PM |
Axial interior parts tree question (steering wheel diameters) | GreenRiver | General Scale Talk | 2 | 02-01-2010 06:00 PM |
